Bucklespring or any other clicking noise emulator
Hi all, :wave:
does anyone have some practical experience with bucklespring :question:
Here´s the background to my question:
Back in 2020 I wanted to insert a clicking noise whenever any keyboard key was hit. Here´s what I had in mind back then:
I was looking for a program that made a clicking sound every time you pressed a key on the keyboard.
I used to use an old mechanical typewriter in the past, and now I somewhat miss that audible feedback.
During my research I came across “bucklespring”: Make Your Keyboard Sound Like The Old Buckle Spring Keyboards In Linux .
You can actually install it not only as a snap package but with apt as well:
rosika@rosika-Lenovo-H520e ~>  buckle
Command 'buckle' not found, but can be installed with:
sudo apt install bucklespring
As a test, back then I installed it in a VM (BodhiLinux). However I was not entirely happy with the result, as the sound reproduced had a lag of around 1/4 to 1/2 second, which was rather irritating. :slightly_frowning_face:
Here I also found the following hint:
With “xset” you should be able to produce a clicking sound in the terminal:
xset c 100 c on
This however didn´t work at all.
So back to bucklespring.
After that I also installed bucklespring on my productive system.
Interestingly, the same phenomenon with the lag could be seen here too. It seems the VM wasn´t to blame for that. :thinking:
As I said, these experiments were carried out some years ago when I was still using Lubuntu. Now I´m on Linux Lite and haven´t bothered with this topic so far.
Before trying anything else I´d like to know if anyone of you has had any experience with bucklespring or any other clicking sound programme.
One thing to bear in mind: the respective programme/process shouldn´t be too hard on RAM or CPU. :wink:
Thanks a lot in advance.
Hi @Rosika ,
There may be something in the accessibility options
Seems to be a snap application in the Ubuntu/Debian repository. Maybe try it in a VM (although it likely will lag).
Hi, @Rosika
I remembered an app I used to use that made the typewriter sounds. It was FocusWriter. But I did have some notes from a long time ago that might be helpful.
There are some implementations to play a sound for every keypress, one of them is “keypress” on Github.com, made by Github user “chrelad”. It’s a fork of linux-typewriter.
And I never checked out: GitHub - aitjcize/Qwertickle: Typewriter sound effect for your keyboard on Linux
Hope you find something.
Performing a search, I found this.
“I can find the following packages if I search for “keyboard sound” with my distro’s package manager:”
bucklespring
mechvibes
keysound
realneptune
Here’s the website links I can see in the details for those packages:
Hi all, :wave:
thanks so much for your replies. :heart:
@nevj :
Thanks for the suggestion, Neville.
But I fear I don´t quite understand. What do you mean? How can I look for it?
@berninghausen :
It seems it can be installed regularly as well (see my post #1). No snap needed, I hope.
Also: Ubuntu – Package Search Results – bucklespring does indeed list it. At present however the site seems to be unavailable.
@Sheila_Flanagan :
Thanks a lot for your suggestions, Sheila.
I found focuswriter here:
Seems to be a complete word processor. Might be a bit over the top for my purposes of just getting some clicking sounds.
However, I´ll take a closer look at it.
Thanks also for the other suggestions. :heart:
@easyt50 :
How kind of you for doing some research and coming up with quite a collection of references, dear Howard. Thank you very much. :heart:
Seems I´ll have to do quite some preliminary reading before getting on with the subject. But that´s a good thing. :wink:
Thank you again to all of you.
Most distros have a menu item called Accessibility… it is for people who struggle with access and want large fonts and other things.
I thought there might be a keyboard click item there.
Have not had time to check, sorry.
Hi Neville, :wave:
Ah, I see what you mean. Thanks for the suggestion.
Yes, there´s soemthing like that in Linux Lite, too.
It´s called “Barrierefreiheit” in the German language version.
There are settings for the mouse and keyboard in it, but no clicking sounds. :neutral_face:
Available keyboard settings are:
  • keys snapping into place
  • decelerated keys
  • keys springing back
Interesting. I never knew such settings were available. :wink:
Seems I have to look for 3rd party tools after all.
Never mind. @Sheila_Flanagan and @easyt50 have provided me with a collection of possibilities.
Thanks and cheers from Rosika :slightly_smiling_face:
Hi again, :wave:
in the meantime I gave bucklespring another try.
I hadn´t installed it on Linux Lite before. My experience regarding the lag dated back to my Lubuntu days.
To my surprise it seems to work quite well now. :smiley:
No discernible lag so far. And it doesn´t seem to be all too heavy on the CPU either.
One thing though:
The volume of the clicking sounds seems a bit low. In actual fact the sounds my keyboard produces are a bit louder.
I haven´t found an option to tweak the volume yet.
These are the options available:
buckle -h
bucklespring version 1.4.0
usage: buckle [options]
options:
  -d DEVICE use OpenAL audio device DEVICE
  -f        use a fallback sound for unknown keys
  -g GAIN   set playback gain [0..100]
  -m CODE   use CODE as mute key (default 0x46 for scroll lock)
  -h        show help
  -l        list available openAL audio devices
  -p PATH   load .wav files from directory PATH
  -s WIDTH  set stereo width [0..100]
  -v        increase verbosity / debugging
I thought the -g option would fit the bill but it doesn´t.
If I set it to 100 it´s equal to the default value.
Of course I could increase the volume of my system altogether but this would be too loud for some other applications, like the Big Ben chimes triggered by cron…
… or for the sound of incoming e-mails etc.
Does anyone know of a way to tweak the volume of a single process, in this case of bucklespring, without affecting the ouptut volume of anything else :question:
Perhaps it cannot be done… :thinking:
Thanks and many greetings from Rosika :slightly_smiling_face:
I think you have to use the sound system… ie tweak the pulseaudio volume control
Even a simple click requires the sound card and its software.
I see, you want the overall sound untouched?
Well does pulseaudio not have control over inputs? Tweak the input, not the output.
Hi Neville, :wave:
thanks a lot for the confirmation.
That´s what I thought as well.
Never mind. At least I got it running. :wink:
Whenever I feel the urge to use bucklespring for an extended period of time I may want to switch off the Big Ben chimes etc. temporarily…
… and increase the system volume.
@nevj and all:
Hi again, :wave:
I actually found a way of turning up the volume of the bucklespring process without affecting any other sound output streams:
The pavucontrol GUI provides a simple way of achieving the task:
For this I had to…
  • click on the loudspeaker symbol in the taskbar
  • click on the sound mixer entry
This led me to the settings GUI: see screenshot above.
Here I could tweak the volume of just buckle.
As you can see I set it to 136%, which seems the right volume for me.
Seems it can be done after all. :wink:
