Some on this forum have entertained the thought of using old hardware
for a Linux machine. I have an Acer desktop PC with a bios date of 2006,
and it just might qualify. The machine started life with Windows Home Basic
installed on a 160GB HDD, 2GB ram and NvidiaGeforce 6100 onboard graphics.
HDD gave up the ghost a long time ago, it has been replaced with a 500GB
Seagate HDD. Ram has been maxed out to 4GB, more about graphics later!!!
I will be using Gentoo 32BIT for this build, why, simply because it is more flexible,
and can be tweaked to fit the hardware, and even that is sometimes a challenge.
I will say, a desktop PC, compared to a laptop, certain hardware can be updated a lot
easier, as you will see in the build. The next few screenshots will kind-of document my
adventure. I am no stranger to Gentoo, so let us start building.
The first thing I did was boot the machine with gparted and make and set the
partitions
/dev/sda1 ntfs was made for Windows Vista Basic
/dev/sda3 ntfs was made for a DATA partition
/dev/sda2 extended was made for Linux
/dev/sda5 swap
/dev/sda6 ext2 GentooBoot
/dev/sda7 ext4 GentooRoot
Vista was installed first without any problem, everything worked, except Internet Explorer,
which hasn’t worked since IE11. Gentoo was a totally different animal.
I then booted with the 32Bit Gentoo CD and set the mount points on the Linux partitions.
and was then ready to compile Gentoo.
The first thing I run is " ip a " to check if internet is up, and write down the name, mine was.
" enp3s0 ". Use " ping -c 3 www.gentoo.org " to check for contivity and use " net-setup enp3s0 " for
dhcp.
For Gentoo you will have to edit the make.conf to fit your machine, when first opened, all you
will see are the first 5 entries, the rest are for you, the installer.
The neuveau graphic driver would not boot the NvidiaGeForce 6100 so I replaced it with
a GeForce GT 430. Changed make.conf from neuveau to nvidia and booted into my X
environment.
After a week of compiling and tweaking I have the Acer running Vista and Gentoo with Xfce. Took
about a day to install Vista and a week to compile Gentoo. If it was all I had, I could live
with it, but I doubt it will see much use.
