I am using Ubuntu 20.04
My current wifi interface name is wlx503eaa24b125
which to too long.
Is there any command to rename it?
This is one way:
nmtui
Open your terminal, and enter the command above.
Or, if you havenβt done it yet, here is an explanation of a way to get what you are after:
