└─# sudo apt upgrade 130 ⨯
Reading package lists… Done
Building dependency tree… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
9 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3 (3.10.4-1+b1) …
running python rtupdate hooks for python3.10…
dpkg-query: package ‘command-not-found’ is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
Traceback (most recent call last):
File “/usr/bin/py3clean”, line 210, in
main()
File “/usr/bin/py3clean”, line 196, in main
pfiles = set(dpf.from_package(options.package))
File “/usr/share/python3/debpython/files.py”, line 53, in from_package
raise Exception(“cannot get content of %s” % package_name)
Exception: cannot get content of command-not-found
error running python rtupdate hook command-not-found
dpkg-query: package ‘commix’ is not installed
main()
Exception: cannot get content of commix
error running python rtupdate hook commix
dpkg-query: package ‘creddump7’ is not installed
main()
Exception: cannot get content of creddump7
error running python rtupdate hook creddump7
dpkg-query: package ‘dnsrecon’ is not installed
main()
Exception: cannot get content of dnsrecon
error running python rtupdate hook dnsrecon
dpkg-query: package ‘fern-wifi-cracker’ is not installed
main()
Exception: cannot get content of fern-wifi-cracker
error running python rtupdate hook fern-wifi-cracker
dpkg-query: package ‘gedit’ is not installed
main()
Exception: cannot get content of gedit
error running python rtupdate hook gedit
dpkg-query: package ‘gobject-introspection’ is not installed
main()
Exception: cannot get content of gobject-introspection
error running python rtupdate hook gobject-introspection
dpkg-query: package ‘john-data’ is not installed
main()
Exception: cannot get content of john-data
error running python rtupdate hook john-data
dpkg-query: package ‘legion’ is not installed
main()
Exception: cannot get content of legion
error running python rtupdate hook legion
dpkg-query: package ‘powershell-empire’ is not installed
main()
Exception: cannot get content of powershell-empire
error running python rtupdate hook powershell-empire
dpkg-query: package ‘recon-ng’ is not installed
main()
Exception: cannot get content of recon-ng
error running python rtupdate hook recon-ng
dpkg-query: package ‘responder’ is not installed
main()
Exception: cannot get content of responder
error running python rtupdate hook responder
dpkg-query: package ‘set’ is not installed
main()
Exception: cannot get content of set
error running python rtupdate hook set
dpkg-query: package ‘spiderfoot’ is not installed
main()
Exception: cannot get content of spiderfoot
error running python rtupdate hook spiderfoot
dpkg-query: package ‘sqlmap’ is not installed
main()
Exception: cannot get content of sqlmap
error running python rtupdate hook sqlmap
dpkg-query: package ‘unicorn-magic’ is not installed
main()
Exception: cannot get content of unicorn-magic
error running python rtupdate hook unicorn-magic
dpkg: error processing package python3 (–configure):
installed python3 package post-installation script subprocess returned error
exit status 4
dpkg: dependency problems prevent configuration of python3-psutil:
python3-psutil depends on python3 (<< 3.11); however:
Package python3 is not configured yet.
python3-psutil depends on python3 (>= 3.9~); however:
python3-psutil depends on python3:any; however:
dpkg: error processing package python3-psutil (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-six:
python3-six depends on python3:any; however:
dpkg: error processing package python3-six (–configure):
dpkg: dependency problems prevent configuration of python3-configobj:
python3-configobj depends on python3-six; however:
Package python3-six is not configured yet.
python3-configobj depends on python3:any; however:
dpkg: error processing package python3-configobj (–configure):
dpkg: dependency problems prevent configuration of python3-gi:
python3-gi depends on python3 (<< 3.11); however:
python3-gi depends on python3 (>= 3.9~); however:
python3-gi depends on python3:any; however:
dpkg: error processing package python3-gi (–configure):
dpkg: dependency problems prevent configuration of python3-gi-cairo:
python3-gi-cairo depends on python3-gi (= 3.42.1-1); however:
Package python3-gi is not configured yet.
python3-gi-cairo depends on python3 (<< 3.11); however:
python3-gi-cairo depends on python3 (>= 3.9~); however:
dpkg: error processing package python3-gi-cairo (–configure):
dpkg: dependency problems prevent configuration of terminator:
terminator depends on python3-configobj; however:
Package python3-configobj is not configured yet.
terminator depends on python3-gi; however:
terminator depends on python3-gi-cairo; however:
Package python3-gi-cairo is not configured yet.
terminator depends on python3-psutil; however:
Package python3-psutil is not configured yet.
terminator depends on python3:any; however:
dpkg: error processing package terminator (–configure):
dpkg: dependency problems prevent configuration of python3-dbus:
python3-dbus depends on python3 (<< 3.11); however:
python3-dbus depends on python3 (>= 3.9~); however:
python3-dbus depends on python3:any; however:
dpkg: error processing package python3-dbus (–configure):
dpkg: dependency problems prevent configuration of python3-cairo:amd64:
python3-cairo:amd64 depends on python3 (<< 3.11); however:
python3-cairo:amd64 depends on python3 (>= 3.9~); however:
python3-cairo:amd64 depends on python3:any; however:
dpkg: error processing package python3-cairo:amd64 (–configure):
Errors were encountered while processing:
python3
python3-psutil
python3-six
python3-configobj
python3-gi
python3-gi-cairo
terminator
python3-dbus
python3-cairo:amd64
E: Sub-process /usr/bin/dpkg returned an error code (1)
