I have just been asked a question, comparing linux against windows. Linux won on almost every point… except one i could not answer.
Screen capture of a video.
I know how to get a video from youtube and download the whole thing using a software tool.
But
If you are watching a video such as a game, WhatsApp conference, or part of a youtube video etc. Just to capture a part.
In windows you use windows key plus control plus R and that brings up a small screen to start the saving with a small control panel to stop. Then it just saves it into a folder as a film.
That i could not give an equivalent
I know just to do a screen image, prnt scrn or ctrl prnt scrn but video had me stumped.
If I press PrtScrn - and opt to take a screenshot of the desktop - it DOESN’T screenshot the screenshot tool itself… If I choose to screenshot a marquee selection - of the specifically the screenshot tool - it takes a screen shot of what’s UNDER the marquee selection - but NOT the screenshot tool itself!
It’s not a huge issue…
i.e. you can use the screenshot tool in Gnome to record video… I’ve accidentally done it in the past…
I meant you need 2 instances of the screenshot app
You seem to be screenshotting 2 windows?
Oh, I get it , you cheated and used my image from the forum.
So you are saying, embed the screenshot window inside some other app, and then screenshot it. … might work.
That is basically what I did putting it in another workspace.
