One can use CUPS via localhost:631 in the browser to check printer queues, but it involves a lot of clicking and there is a simple command
lpq -a
which will list the contents of all printer queues.
Having just conquered an issue with CUPS and my Brother printer in Debian, involving a complete reinstall of both CUPS and the printer drivers, I was dismayed to find that lpq was not working.
The command was present
# which lpq
/usr/bin/lpq
but it did nothing. Normally if all queues are empty it says ‘No entries’
So how come lpq works in Debian on my other machine, and in Devuan, but not in the Debian that I have just reinstalled CUPS in?
It turns out there are two sources of the lpr command… two packages can supply lpr
nevj@trinity:~$ apt-file show lpr
lpr: /etc/cron.weekly/lpr
lpr: /etc/default/lpd
lpr: /etc/init.d/lpd
lpr: /etc/logcheck/ignore.d.server/lpr
lpr: /usr/bin/lpq
lpr: /usr/bin/lpr
lpr: /usr/bin/lprm
lpr: /usr/bin/lptest
lpr: /usr/sbin/lpc
lpr: /usr/sbin/lpd
lpr: /usr/sbin/lpf
lpr: /usr/sbin/pac
lpr: /usr/share/doc/lpr/README.Debian
lpr: /usr/share/doc/lpr/changelog.gz
lpr: /usr/share/doc/lpr/copyright
lpr: /usr/share/doc/lpr/examples/printcap
lpr: /usr/share/man/man1/lpq.1.gz
lpr: /usr/share/man/man1/lpr.1.gz
lpr: /usr/share/man/man1/lprm.1.gz
lpr: /usr/share/man/man1/lptest.1.gz
lpr: /usr/share/man/man5/printcap.5.gz
lpr: /usr/share/man/man8/lpc.8.gz
lpr: /usr/share/man/man8/lpd.8.gz
lpr: /usr/share/man/man8/lpf.8.gz
lpr: /usr/share/man/man8/pac.8.gz
apt-file show cups-bsd
cups-bsd: /usr/bin/lpq
cups-bsd: /usr/bin/lpr
cups-bsd: /usr/bin/lprm
cups-bsd: /usr/sbin/lpc
cups-bsd: /usr/share/doc/cups-bsd
cups-bsd: /usr/share/man/de/man1/lpq.1.gz
cups-bsd: /usr/share/man/de/man1/lpr.1.gz
cups-bsd: /usr/share/man/de/man1/lprm.1.gz
cups-bsd: /usr/share/man/de/man8/lpc.8.gz
cups-bsd: /usr/share/man/fr/man1/lpq.1.gz
cups-bsd: /usr/share/man/fr/man1/lpr.1.gz
cups-bsd: /usr/share/man/fr/man1/lprm.1.gz
cups-bsd: /usr/share/man/fr/man8/lpc.8.gz
cups-bsd: /usr/share/man/man1/lpq.1.gz
cups-bsd: /usr/share/man/man1/lpr.1.gz
cups-bsd: /usr/share/man/man1/lprm.1.gz
cups-bsd: /usr/share/man/man8/lpc.8.gz
I have always installed BOTH packages (lpr and cups-bsd)
ii lpr 1:2008.05.17.3 amd64 BSD lpr/lpd line printer spooling system
dpkg -l | grep cups-bsd
rc cups-bsd 2.3.3op2-3+deb11u2 amd64 Common UNIX Printing System(tm) - BSD commands
It would seem that what ends up in /usr/bin/lpr depends on which package I installed last
it probably means I should not have both packages installed
see here
https://unix.stackexchange.com/questions/134083/how-do-i-get-the-right-lpr-for-cups-installed-on-ubuntu-server-14-04
So I did an experiment
root@trinity:~# apt-get purge lpr
root@trinity:~# apt-get purge cups-bsd
root@trinity:~# apt-get install cups-bsd
So now I only have cups-bsd package
Try lpq again
root@trinity:~# lpq -a
no entries
That looks better
Now make another test print and see if lpq sees it
Rank Owner Job File(s) Total Size
active unknown 9 unknown 1024 bytes
Yes it does.
So the answer to the lpq mystery is
use the cups-bsd package with CUPS… do not also install the lpr package
what happens if you install both depends on the order in which they are installed. (It would seem I have been lucky with other installs and fluked them in the right order)
Still one question
Does anyone know what the lpr package is used for, if it is not to be used with CUPS?
And one last wish
Could we please have a print system with a few less mantraps, and a package system that tells you what each package is intended to be used for?
