Hi all, ![]()
I use the web-stick Huawei E3372_LTE for establishing my internet conection. I´ve been using it for about 2 years now and normally it works reliably.
Something odd happened today though. ![]()
In order to connect to the internet I use the web-interface provided by the stick. If everything goes well it looks like this:
Today however I was presented with an error:
“Kein Dienst. Für Ein-Klick-Check hier klicken”. All in German. I´ll try to translate:
“No service. Click for One-Click-Check”. :
O.K. I did that, but to no avail. Here´s the new message:
It says: “SIM-Lock-code: locked” and “Mobile Data: de-activated”… which seems pretty nonsensical to me as I didn´t change anything. ![]()
I finally got I working by selecting the option “Neustart” = restart" from the menu. ![]()
This worked immediately and I got a good connection like in the first picture.
This phenomenon has happened before, but only once. It was months ago. Back then I rebooted my OS and after that it worked.
This time I didn´t want to reboot the computer, so I managed to fix it with the stick´s internal “restart” option via the web-interface.
Well, of course I´d like to know what was going on. ![]()
The “no service” message seems to be the crucial one. It almost looks as if something (some service) didn´t start the normal way.
If so, why would that have been the case ![]()
As I said, up till now this has happened twice. So it´s not something that occurs regularly. But still: it made me wonder what was amiss.
Does anyone of you have a clue?
Thanks a lot in advance.
Many greetings
Rosika ![]()
