My question is how to add a “select location” choice to the right-click options in Caja for either “Move to…” or “Copy to…”.
Now, it only allows Home or Desktop.
I searched a bit for the answer and found this:
It did not work. Where the directions said this would happen:
To use the action:
Right-click the file you want to copy and select Caja-Actions actions → Copy to
In the popup window, select the directory you wish to copy the file to and click OK
The file will be copied
my context menu had no options for Caja-Actions, and the options for move or copy were no different.
Is there a better way?
