Debian 13: MDS CPU bug present and SMT on, data leak possible
Hello Friends
In Debian 13 Desktop in a Lenovo Z50-70, after the GRUB is loaded is shown a long output of a situation starting with:
MDS CPU  bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html......
more
Because the output is long I did a research about how to see the same output.
Well after to execute the journalctl -b command as root was possible to re-create the same block report as follows:
MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
hpet_acpi_add: no address or irqs in _CRS
ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
usb: port power management may be unreliable
ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20240827/psargs-332)
ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
nouveau 0000:03:00.0: drm: failed to create ce channel, -22
nouveau 0000:03:00.0: bus: MMIO write of <somecode> FAULT at 6013d4 [ PRIVRING ]
nouveau 0000:03:00.0: [drm] No compatible format found
I read both links but because I am not expert … I need know your point of view
  • How serious is this situation?
It seems if is used some virtualization tool such as VirtualBox is possible that the guest can “harm” the host …
  1. Did I understand correctly?
  2. Am I missing something?
If I am correct for (1)
a. How common is this?
b. How is possible that situation?
Pls could you share your thoughts? A guidance is well welcome
Thanks in advance
I think this has been around for some time.
may provide some guidance.
Thanks for the links …
According with the suggested solution it has an impact of performance in the processor
