Hi from germany.
What exactly seems to be the problem?
What do you mean with “DNS keeps changing”?
I assume that you are connected to some kind of router from your ISP (via cable or wifi).
Are there other computers (smartphones, tablets) in your home, that have the same problem?
When did this problem start?
Many questions, but we have to know some basics to get to the problem…
mem 3.7gb
intel pentum [R] G3250@3.20ghz = 2
graphics intel haswell desktop
grome 3.28.2
os typoe 64 bit
I looked on the net on how to fix dns problem and followed the instructions done via terminal
the change lasted about 2 minutes I was able to access linuxmint.com then when I tried to install
mint 19.1 was not able to access linuxmint again
I have a box in the house here that I plug the computer into for the internet
I can ping the internet service but how to change anything is beyond me
Thank you Fast.Edi
Bill
So you can access the internet (e.g. amazon.com, debian.org, …), but explicitely not the domain “linuxmint.com”?
What exactly did you do in the terminal?
What do you mean by “I tried to install mint 19.1”?
Have you started your system with a DVD/USB of Mint 19?
Normally the router is set to provide (internal) IPs and DNS automatically and this works fine in most cases.
Have you tried to start the router/modem new (just take away power for a couple of minutes and plug it in again)?
