Because the nature of UPS I’d have it connected and powered up always.
I don’t understand this fear of a switchable power strip?
https://www.mediamarkt.de/de/product/_nedis-exso515ueswt-verlangerungsbuchse-102769186.html
What’s the problem with that extension?
It’s rated for 16 A, I have more of such (very similar) items, the switch in them are dual circuit switches, they disconnect both wires (active, neutral).
Disconnecting protective earth is not necessary.
The surge protectors cosumption is negligible.
The UPS will consume, as it has its own idle power, and has to keep the battery charged, so it will take I guess between 5 to 15W.
Monitor, printer, other periferals usually take 1 … 2W in standby, the PC itself can draw 5W in standby. Assuming 1 printer, 1 monitor, and a PC, the thing could draw 7W together when not in use. Say it is used for 5 hours a day, then the rest means approx. 4 kWh in a month, 49kWh in a year.
(Thi is just an estimation, the actual values should be measured).
How much money is that depends on the price of electricity. I totally understand @Rosika if she wants to completely switch off everything, and to get a real zero standby consumption.
Before energy price boom our house consumed 4700kWh in a year.
Did not care too much, we could afford easily. We already had LED lights.
After the boom, I looked around in the house, and minimized the number of stand-by devices (we had a huge lot of them!) now the yearly consumption is reduced to 3300 kWh, but I changed my server to an Odroid, which has cut the consumption from ~20W to ~5W
So those stand-by Watts may matter, even if they seem to be negligible.
