Damn! I was going to give NextCloud another “spin”… I got it going about 5 years ago on my NAS but ended up going with ResilioSync and removed Nextcloud…
Just tried again (FreeNAS) and WHAT A GIGANTIC PILE of SHIT it is now, to get going! Last time it “click here, click there, install plugin and BANG!”… It was almost TOO EASY!
Now? It gives you some vague message about config.php and trusted domains - what a stinker!
Took me ages to figure that out. i.e. I gave up yesterday (Saturday) arvo / evening, just revisited this morning (Sunday).
Get past that - then I have to find the default password for admin user - get there, eventually.
Then I get “unspecified error” occurred please check log file. WHICH SHITTING LOG FILE? The logfile in the nextcloud config.php file, in the BSD Jail is :
/var/log/nextcloud/nextcloud.log
and it looks like UGLY gigantic strings of JSON (I can’t tell 'cause it looks garbled) - e.g. ( this is all one single frigging line, the last line (tail -1) :
{"reqId":"37FBp7LLiuwG6zxedNdo","level":3,"time":"2022-02-13T03:24:17+00:00","remoteAddr":"10.1.1.162","user":"ncadmin","app":"index","method":"GET","url":"/apps/dashboard/undefined/js/firstrunwizard-main.js","message":"An exception occurred while executing a query: SQLSTATE[HY001]: Memory allocation error: 1038 Out of sort memory, consider increasing server sort buffer size","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36","version":"22.1.1.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[HY001]: Memory allocation error: 1038 Out of sort memory, consider increasing server sort buffer size","Code":1038,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1728,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1667,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1040,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":231,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":210,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1340,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1276,"function":"getRows","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequestBuilder.php","line":123,"function":"asItems","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequest.php","line":339,"function":"getItemsFromRequest","class":"OCA\\Circles\\Db\\ShareWrapperRequestBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Service/ShareWrapperService.php","line":180,"function":"getSharedWith","class":"OCA\\Circles\\Db\\ShareWrapperRequest","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/ShareByCircleProvider.php","line":557,"function":"getSharedWith","class":"OCA\\Circles\\Service\\ShareWrapperService","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Share20/Manager.php","line":1360,"function":"getSharedWith","class":"OCA\\Circles\\ShareByCircleProvider","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/files_sharing/lib/MountProvider.php","line":79,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":118,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":429,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":354,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":325,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1023,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/usr/local/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":114,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY001]: Memory allocation error: 1038 Out of sort memory, consider increasing server sort buffer size","Code":1038,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":84,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1030,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":231,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":210,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1340,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1276,"function":"getRows","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequestBuilder.php","line":123,"function":"asItems","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequest.php","line":339,"function":"getItemsFromRequest","class":"OCA\\Circles\\Db\\ShareWrapperRequestBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Service/ShareWrapperService.php","line":180,"function":"getSharedWith","class":"OCA\\Circles\\Db\\ShareWrapperRequest","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/ShareByCircleProvider.php","line":557,"function":"getSharedWith","class":"OCA\\Circles\\Service\\ShareWrapperService","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Share20/Manager.php","line":1360,"function":"getSharedWith","class":"OCA\\Circles\\ShareByCircleProvider","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/files_sharing/lib/MountProvider.php","line":79,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":118,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":429,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":354,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":325,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1023,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/usr/local/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY001]: Memory allocation error: 1038 Out of sort memory, consider increasing server sort buffer size","Code":"HY001","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":82,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1030,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":231,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":210,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1340,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/vendor/artificial-owl/my-small-php-tools/lib/Db/Nextcloud/nc22/NC22ExtendedQueryBuilder.php","line":1276,"function":"getRows","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequestBuilder.php","line":123,"function":"asItems","class":"ArtificialOwl\\MySmallPhpTools\\Db\\Nextcloud\\nc22\\NC22ExtendedQueryBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Db/ShareWrapperRequest.php","line":339,"function":"getItemsFromRequest","class":"OCA\\Circles\\Db\\ShareWrapperRequestBuilder","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/Service/ShareWrapperService.php","line":180,"function":"getSharedWith","class":"OCA\\Circles\\Db\\ShareWrapperRequest","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/circles/lib/ShareByCircleProvider.php","line":557,"function":"getSharedWith","class":"OCA\\Circles\\Service\\ShareWrapperService","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Share20/Manager.php","line":1360,"function":"getSharedWith","class":"OCA\\Circles\\ShareByCircleProvider","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/files_sharing/lib/MountProvider.php","line":79,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Config/MountProviderCollection.php","line":118,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":429,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Files/Filesystem.php","line":354,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":325,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1023,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/usr/local/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":82}},"CustomMessage":"--"}}
seriously - how can a human being be expected to debug crap like that??? The developer should be taken (quietly) down the back paddock and put out of our misery, with a quick, discrete, bullet…
