I like to avoid to much blue light in the evening. F.Lux doesn’t work anymore.
Any suggestion for an alternative?
Have you tried Redshift?
The company offer a tech support page at
But cannot see any references to your question
I would be tempted to look at your settings for the screen and if it is a Nvidia issue over controlling a setting
Never used this product so no other options of software, I just turn the brightness down manually to suit general light conditions
i don’t use any of the above, but found some other options listed here:
Thank you all for teh suggestions. I will try them out
Redshift works good for me and is still under development.
On LMDE, QRedshift does very well.
https://cinnamon-spices.linuxmint.com/applets/view/313
For so far I can see it doesn’t work on Xubuntu, but now I’m using iris-mini-0.3.8.AppImage and it’s working fine .
