FingerPrint issue in Ubuntu 20.04
can you help me Mr. Abhishek Prakash?? I installed Ubuntu 20.02 LTS but in setting>user , i do not found fingerprint .. i am not able to use my fingerprint in ubuntu. plzz help me…
I got same problem on my laptop, I think there is no simple way to use fingerprint on linux
hope anyone can give the solution please.
thank you
Hey folks,
This also depends upon the system manufacturer. Some have out of the box compatibility with Linux while some might require additional stuff and if there are no drivers support at all, then it won’t work at all in some cases.
@nurohman
You would have to install drivers for it then Try it .
I try some driver installation on hp probook 430g5 but had no luck
@nurohman
hp.com/support
Enter your Serial Number and Check if there are drivers for Linux
@nurohman
Fingerprint Problem
