Hi all, ![]()
I stumbled over a curious problem yesterday, but in the meantime it´s solved (the problem resolved itself somehow).
Still: I´m curious what might have been going on. ![]()
Out of nowhere (at least it seems that way) the GUI representation of firetools (Graphical tools collection for Firejail security sandbox) changed
in a visual way.
Here´s what it normally looks like:
But suddenly some of the icons had a different visual representation. They still pointed to the correct applications though.
It´s hard to describe with words and I didn´t think of taking a screenshot at the time. ![]()
Plus: the fonts had changed too. The characters were depicted a little smaller than usual.
The strangest thing was:
I got the changed representation of firetools only when double-clicking on the respective desktop icon:
When starting it via the terminal with the command firetools it was back to its old self again. ![]()
So I tried to look it up in the logs with the help of lnav. Looking for the search word firetools I came across these entries:
│Jul 13 18:31:21 rosika-Lenovo-H520e Thunar[94779]: Das Arbeitsverzeichnis »/home/rosika/[Invalid UTF-8]« ist nicht vorhanden: Es wird beim Starten von »firetools« nicht verwendet. │
│Jul 13 18:31:21 rosika-Lenovo-H520e Thunar[97084]: exiting...
This would be:
"The working directory “/home/rosika/[Invalid UTF-8]” does not exist: it is not used when starting “firetools”.
Strange. ![]()
Well, I shut down my system, as it was already bed time for me.
When starting anew today everything seems to back to normal again. ![]()
No idea what was going on yesterday.
Does anyone have a clue?
Thanks and many greetings from Rosika ![]()
P.S.:
I remember having fiddled with “ImportExportTools NG” in thunderbird before it all happened.
I had changed the “character set for export in text and csv format” a few times but finally switched back to UTF-8 again.
I wonder whether this had something to do with it…
… especially in view of the fact that thunderbird was started via the firetools app.
