FreeBSD - a Unix type of OS
Thats why we created the Pennines keep everyone out.
So did the French create the Alps for the same reason?
Yes And the spanish built the Pyrenees
All copies of the Yorkshire idea
Could it perhaps be that people originally settled in valleys, so mountains became a divide.?
I must say I was impressed. Seeing such a historical landmark that I had only seen on TV.
Read Fred Hoyle ā€œOn Stonehengeā€
Cheaper on abebooks
Good idea, but we built our mountain to keep Lancashire people out.
So Britain used to be ā€˜flat earth’ until you Yorkies dug it up?
Slight correction
When the men from Yorkshire created the world… and someone said let there be light. The Yorkshire men said who is paying the bloody electricity bill.
back to topic :laughing:
I’ve reinstalled FreeBSD 15.0 with ZFS filesystem. Here’s how it looks after automatic install with USB .iso:
pete@FreeBSD:~ $ df -h
Filesystem            Size    Used   Avail Capacity  Mounted on
zroot/ROOT/default    229G    4.8G    224G     2%    /
devfs                 1.0K      0B    1.0K     0%    /dev
/dev/gpt/efiboot0     256M    1.3M    255M     0%    /boot/efi
procfs                8.0K      0B    8.0K     0%    /proc
zroot/var/log         224G    304K    224G     0%    /var/log
zroot/tmp             224G    5.2M    224G     0%    /tmp
zroot                 224G     96K    224G     0%    /zroot
zroot/home            224G     96K    224G     0%    /home
zroot/var/audit       224G     96K    224G     0%    /var/audit
zroot/usr/src         224G     96K    224G     0%    /usr/src
zroot/var/mail        224G    136K    224G     0%    /var/mail
zroot/var/crash       224G     96K    224G     0%    /var/crash
zroot/var/tmp         224G     96K    224G     0%    /var/tmp
zroot/usr/ports       224G     96K    224G     0%    /usr/ports
zroot/home/pete       224G     72M    224G     0%    /home/pete
I have only one SSD disk for this so no RAID. Need to learn how to make snapshots. I have tried the Btrfs on Linux earlier but will read about ZFS next. Any ideas how to proceed?
My first reaction is alarm. … it frightens me having to learn about all those partitions. Telling me they are not real partitions but just something logical within zfs does not calm me. A lot of it is fear of the unknown … I am sure it could be made to work.
You shall find out if it has any advantages.
This is my hobby computer so no need to worry! Learning experience to zfs
I use FreeBSD a tiny bit more than Linux, and must say, even on my low-spec computer, it runs smoothly. I feel it gives you more control than Linux (compiling with ports) and itā€˜s way more conpatible witj my devices. Sreongly recommend anyone to try it.
You would like Gentoo (if you haven’t already tried it)! I find ports too complicated compared to Gentoo’s portage. With Gentoo you have USE flags but with FreeBSD’s ports you need to select/deselect all during builds. I use pkg with FreeBSD .
Btw, made my first snapshot. Now I’ll wait for some updates and the I try to roll back to see if it works
Well on the other side, I find gentoo pretty problematic. With ports, I just can use menuconfig. With Gentoo, with USE flags, I can break my system (fun fact: has happened on ALL my installations! due to conflicting use flags). But the worst thing about ports is the size… Created a dummy 100GB disk and installed. Latest git commit is totally sized 21.2GB. I think there should be an option to individually check out categories. For example, I have deleted games, and it always appears after git pull. Gentoo does that better, but I think there should also be an option to use gmake / bmake instead of ebuild in the repo.
I have never broke my Gentoo installs. I have it on all my computers. I don’t use global ~amd64 on my make.conf and only enable guru (never any others) on some of my machines. I have only few use flags (and - flags) on my make.conf and use more /etc/portage/package.use/<package_name> for the special flags for that one package. Here’s my laptop’s make.conf:
ā”Œā”€[pete@gentoo]─[~]
└──╼ cat /etc/portage/make.conf
# These settings were set by the catalyst build script that automatically
# built this stage.
# Please consult /usr/share/portage/config/make.conf.example for a more
# detailed example.
WARNING_FLAGS="-Werror=odr -Werror=lto-type-mismatch -Werror=strict-aliasing"
COMMON_FLAGS="-O2 -pipe -march=x86-64-v3 -flto ${WARNING_FLAGS}"
CFLAGS="${COMMON_FLAGS}"
CXXFLAGS="${COMMON_FLAGS}"
FCFLAGS="${COMMON_FLAGS}"
FFLAGS="${COMMON_FLAGS}"
FEATURES="${FEATURES} getbinpkg"
FEATURES="${FEATURES} binpkg-request-signature"
FEATURES="candy parallel-fetch parallel-install -merge-wait unmerge-orphans"
# NOTE: This stage was built with the bindist Use flag enabled
MAKEOPTS="-j7 -l6"
EMERGE_DEFAULT_OPTS="-avg --keep-going --jobs 7"
USE="X wayland lto elogind udev xorg wireless bluetooth cups acl policykit dbus -ipv6 -dvd -dvdr -cdr -kde -plasma -gnome -gnome-online-accounts -selinux -ios -ipod -thunderbolt"
USE="${USE} networkmanager"
PORTAGE_SCHEDULING_POLICY="idle"
ACCEPT_LICENSE="*"
INPUT_DEVICES="libinput synaptics"
VIDEO_CARDS="intel"
GRUB_PLATFORMS="efi-64"
LINGUAS="en"
L10N="en-GB"
CPU_FLAGS_X86="aes avx avx2 f16c fma3 mmx mmxext pclmul popcnt rdrand sse sse2 sse3 sse4_1 sse4_2 ssse3"
# This sets the language of build output to English.
# Please keep this setting intact when reporting bugs.
LC_MESSAGES=C.utf8
and I have some extra flags for these packages:
└──╼ ls /etc/portage/package.use/
00cpu-flags clutter dhcpcd-ui gcc libsdl2 openrc polkit qt5compat sddm swaybg virt-manager waybar
cinnamon cups dnsmasq gnome-boxes mesa openvpn pulseaudio qtbase spice sys-kernel virtualbox xdg-desktop-portal-hyprland
cinnamon-control-center cups-meta elogind installkernel mpv pipewire qemu samba sway thunderbird virtualbox-modules
as you can see I haven’t cleaned all the package.use flags (like Hyprland, I’m using Sway atm) but it’s just me being lazy.
This is totally my opinion and I value yours!
I’m not 100% sure why it does it this way - but mine’s similar - that’s GhostBSD in a QEMU / KVM guest :
x@daphnis ~> df -h
zroot/ROOT/default                40G    4.8G     35G    12%    /
linprocfs                        8.0K      0B    8.0K     0%    /compat/linux/proc
tmpfs                            9.1G    4.0K    9.1G     0%    /tmp
linsysfs                         8.0K      0B    8.0K     0%    /compat/linux/sys
fdescfs                          1.0K      0B    1.0K     0%    /dev/fd
zroot/home                        36G    1.1G     35G     3%    /home
zroot/var/audit                   35G     96K     35G     0%    /var/audit
zroot/var/mail                    35G    108K     35G     0%    /var/mail
zroot/tmp                         35G    144K     35G     0%    /tmp
zroot/var/tmp                     35G     96K     35G     0%    /var/tmp
zroot/var/log                     35G    384K     35G     0%    /var/log
zroot/var/crash                   35G     96K     35G     0%    /var/crash
zroot/usr/ports                   35G     96K     35G     0%    /usr/ports
devfs                            1.0K      0B    1.0K     0%    /compat/linux/dev
fdescfs                          1.0K      0B    1.0K     0%    /compat/linux/dev/fd
tmpfs                            9.1G    4.0K    9.1G     0%    /compat/linux/dev/shm
baphomet.local:/mnt/BARGEARSE     10T    9.1T    1.3T    87%    /mnt/BARGEARSE
Seems to use a fair bit less disk space than a recent Debian or Ubuntu install… e.g. I have Debian 13 with Gnome installed in a VM and it’s using 13 GB for ā€œ/ā€ā€¦
I have a basic understanding of those zfs ā€œsetsā€ or ā€œdatasetsā€ (I think that’s the terminology - I also have a Solaris 11.4 (x86) VM - and it also has multiple datasets :
x@slowlardarse00:~$ df -h
Filesystem             Size   Used  Available Capacity  Mounted on
rpool/ROOT/solaris      19G   2.7G        10G    21%    /
rpool/ROOT/solaris/var
                        19G   315M        10G     3%    /var
/devices                 0K     0K         0K     0%    /devices
/dev                     0K     0K         0K     0%    /dev
ctfs                     0K     0K         0K     0%    /system/contract
proc                     0K     0K         0K     0%    /proc
mnttab                   0K     0K         0K     0%    /etc/mnttab
swap                   8.2G   6.5M       8.2G     1%    /system/volatile
swap                   8.2G     4K       8.2G     1%    /tmp
objfs                    0K     0K         0K     0%    /system/object
sharefs                  0K     0K         0K     0%    /etc/dfs/sharetab
fd                       0K     0K         0K     0%    /dev/fd
/usr/lib/libc/libc_hwcap2.so.1
                        13G   2.7G        10G    21%    /lib/libc.so.1
rpool/VARSHARE          19G   2.7M        10G     1%    /var/share
rpool/VARSHARE/tmp      19G    31K        10G     1%    /var/tmp
rpool/VARSHARE/kvol     19G    31K        10G     1%    /var/share/kvol
rpool/VARSHARE/zones    19G    31K        10G     1%    /system/zones
rpool/export            19G    32K        10G     1%    /export
rpool/export/home       19G    32K        10G     1%    /export/home
rpool/export/home/x     19G    36K        10G     1%    /export/home/x
rpool                   19G   4.3M        10G     1%    /rpool
rpool/VARSHARE/pkg      19G    32K        10G     1%    /var/share/pkg
rpool/VARSHARE/sstore
                        19G   1.2M        10G     1%    /var/share/sstore/repo
rpool/VARSHARE/pkg/repositories
                        19G    31K        10G     1%    /var/share/pkg/repositories
/dev/dsk/c1t1d0s2      707M   707M         0K   100%    /media/Oracle_Solaris-11_4-Text-X86
Making the ā€œ/ā€ ZFS - i.e. ā€œrpoolā€ a mirror pair was as simple as :
zpool attach rpool c2d0 c2d1
And now :
root@slowlardarse00:~# zpool status
  pool: rpool
 state: ONLINE
  scan: resilvered 7.03G in 1m03s with 0 errors on Sun Dec 28 12:24:09 2025
config:
        NAME        STATE      READ WRITE CKSUM
        rpool       ONLINE        0     0     0
          mirror-0  ONLINE        0     0     0
            c2d0    ONLINE        0     0     0
            c2d1    ONLINE        0     0     0
errors: No known data errors
