My latest Gentoo update produced strange errors about being unable to compile gcc , and refused to proceed.
After some searching I found that the root filesystem was full.
I have 80GB for /. Some searching revealed that the directory /var/cache/distfiles used 35GB.
The Gentoo docs said I could either delete all files in /var/cache/distfiles, or use eclean to selectively remove some.
I did not have eclean installed, and there was no space to install it, so I deleted the lot.
On a subsequent update, portage replaced some files in /var/cache/distfiles⌠about 45 files using about 2 GB.
the update worked .
So what is this eclean command , and when should I run it⌠obviously I have been neglecting some cleanup requirements. I do use emerge --depclean, but that does not seem to do what is needed?
I do not use eclean but try running â emerge âupdate âdeep ânewuse @world â after you run â emerge-webrsync and emerge âsync â this may pick-up a few packages for â emerge -a âdepclean â .
If you wait for âwifiâ you will never get anywhere with BLFS!!!
I do not know how your host is setup, but you have maybe two options!!!
#1 (The best) Use the host and chroot into LFS, you would have internet and copy and paste!!! Download and compile and install âwget and opensshâ
#2 (If possible) Use a ethernet cable, and you would then log into a âftp serverâ and download and install âwget and opensshâ
#3 After openssh is up and running, and you have access to another PC, you can then ssh to the LFS machine!!! Which is what I do with my W11 machine!!!
Get rid of NetworkManager and any other special network software.
Do it by hand like this
Problems with wifi come from using complicated software that makes unwanted assumptions.
I have not tried LFS but it should be no different from any linux when it comes to setting up wifi.
You will get me into LFS one day. Not sure I could teach anyone anything.
Wifi suffers from well meaning individuals writing packages to âsimplifyâ it, but they end up complicating it.
I just spent 8 months fixing the fuel injector pump on our tractor. ⌠then the starter motor failed. I finally got it started yesterday. There are fuel leaks to trace.
If it only leaks while running, the leak must be on the high pressure side of the pump? Correct?
Sorry, my fault!!! LFS is never meant to be a daily drver, it is and still is meant to be a learning too!!
If one wishes to learn just how a distro is put together, then LFS will do just that!! For someone like you, that is using Gentoo, then the interest in LFS would be normal, Gentoo is LFS, only with a package manager!!!
I have Gentoo and LFS booting on my Acer Mini!!! I sometimes I use Gentoo as the host, using chroot, and, W11 using ssh, to build LFS, which is in the BLFS stage!!! It is a slow process,and takes a lot of time and sometimes one will succeed with a LFS that works!!!
You have everything you need, with Gentoo, so create a partition for LFS and give it a try!!!
