Get threefold statements at shutdown of computer:
- Scanning for signal…;
- No DP signal from your device;
- Going into standby mode.
-computer then shuts down.
What gets me is no.3.
Had same message in Windows 11 and now with KDE Neon.
At least KDE shuts down much faster!
But why state ‘standby mode’ instead of simply ‘shutting down’ (which it does anyhow)?
System:
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.26.4 Distro: KDE neon 22.04 5.26
base: Ubuntu 22.04 LTS Jammy
Machine:
Type: Desktop System: Dell product: OptiPlex 7060 v: N/A
serial:
Mobo: Dell model: 0NC2VH v: A01 serial: UEFI: Dell
v: 1.21.0 date: 07/06/2022
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M280/320/275
charge: 55% (should be ignored) status: Discharging
CPU:
Info: 6-core model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 bogomips: 36000
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell CometLake-S
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Mysher Tech IRIScan Desk 5 Pro type: USB driver: uvcvideo
bus-ID: 1-5.3:4
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.0.5
direct render: Yes
Audio:
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: Logitech H390 headset with microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-11:6
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
Drives:
Local Storage: total: 238.47 GiB used: 13.76 GiB (5.8%)
ID-1: /dev/sda vendor: Kingfast model: N/A size: 238.47 GiB
Partition:
ID-1: / size: 53.1 GiB used: 13.69 GiB (25.8%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 76 MiB (79.2%) fs: vfat dev: /dev/sda1
Swap:
Alert: No swap data was found.
Sensors:
System Temperatures: cpu: 27.8 C pch: 37.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 215 Uptime: 5h 12m Memory: 7.56 GiB used: 3.16 GiB (41.8%)
Init: systemd runlevel: 5 Compilers: gcc: N/A Packages: 1930 Shell: Bash
v: 5.1.16 inxi: 3.3.13
