So, there’s this other OS, it’s not Linux, nor a *BSD. It’s Haiku.
A continuation of BeOS, which was meant as a competitor to Windows, it has quite some interesting features.
It boots fast, REALLY fast, and I only tried its live mode in a VM! Yes, it’s rough around the edges (that’s why it hasn’t got a 1.0 yet), but already it looks promising. Its GUI is really responsive and looks and behaves quite different than the Windows or MacOS-esque GUIs, so takes some getting used to.
@xahodo ,
Not to be confused with Gnu Hurd
I think it is very interesting. Will be trying it, probably a VM or in my spare machine.
There is a Linux Magazine article, which gives some facts without the hype
I remember reading about BeOS twenty something years ago - it was touted as a possible replacement of Mac System7/8/9 - and maybe even Amiga workbench… And the guy who started BeOS had been with Apple for a while too…
Sound interesting - but I won’t be dabbling in it - much like I won’t dabble in ReactOS or that other one that used to run on BBC Acorns and suchlike…
I think that could work best as some kind of an embedded system, where the software just works “as is”, does the job just right, no need to update/upgrade.
Something like an old ancient Ubuntu in an Allen&Heath mixer used in a theater.
Just works, does the job, noone cares the core system is way outdated… it gets the job done.
The last release was beta5 24-09-13, and it is only for IA-32 and x86-64 architectures.
It has a package manager,
It is fixed release and non-systemd
The packages listed by distrowatch look a bit sparse.
It has a strange filesystem called BFS
The best way to get a feel for it is to try an install in VM.
I prefer virt-manager for a linux VM.
Why not try it and then you could report back to us on what it is like to install and what apps you could get and what the DE is like?
Looks more like OS/2 Warp maybe, or NeXTStep to my mind… I always found it quite appealing anyway…
It’s not even Linux or Unix - so the init system wouldn’t be related to anything on Linux or Unix right?
That’s kinda like saying Windows 10 and 11 don’t use SystemD… or MacOS (it uses something called “launchd”).
Anyway - I like MacOS / OS X and kinda glad BeOS (Haiku is basically BeOS) was never taken over by Apple as a Mac System 7/8/9 replacement… I also vaguely remember BeOS (and Haiku) being touted as AmigaOS alternative on M68K and PPC…
VMS (and “OpenVMS”) also had/has a “sh” or a “csh” shell and also X Windows - but it wasn’t (or isn’t) a “UNIX like” operating system - some might argue that Windows NT (and thus Windows 2000, XP, Vista, 7, 8, 10, 11) are “VMS like” operating systems
They are so derived, but using VMS was nothing like using NT or Win . It was painful compared to BSD. I dont remember a shell, but I probably did not realize I was in one.
What I was really thinking was, Haiku’s init system might do much the same thing as Linux inits… start processes by forking.
After reading this, I decided to install Haiku into a QEMU/KVM VM. I looked on the website, and found a KVM installation guide in the documents section. I followed it, and was able to install the OS with no issues.
I haven’t used the OS much yet, but from what I see now, I don’t think it’s ready to be a daily driver yet, although it feels very stable and dependable. Following installation, I was able to find and run the updater to get all my software up to date.
While I like the Haiku experience as it currently is, I’d like to see it evolve into having a more new user-friendly user interface, because that’s how it will grow a very large user base.
Absolutely! It runs in my KVM VM as fast, or faster than my Garuda-KDE-Lite installation on bare metal. I have no issue with the OSes performance. I simply would prefer that the user interface was easier to use/more intuitive.
