Hardening LMDE for beginners
This is my LMDE cheat sheet for those of you that might want to use it. It includes all of the commands to self-host a standalone Snowflake proxy, private Rust game server, and full Monero node as a bonus if you’re interested in any of that.
Make sure to check out each referral for context to understand the purpose of each instruction so that you’re not confused as to what you’re doing, and be sure to tell me if something doesn’t work so that I can correct it on my end.
I can of course expand on this which I will, but this is what I have for now. I’m open to contributions but I’d have to give you edit permissions so I’d prefer it if you were to add me on Matrix first so that we can build trust with each other beforehand.
Keep in mind that there are placeholder values which you must change, and that this is an opinionated cheat sheet of my own making which means you won’t necessarily agree with it.
Thanks, that is useful… not only for LMDE users
If you look at the link be patient… it takes some time to load
Thanks man! Yeah a lot of it can certainly be used on other systems as well. It takes some time to load due to CryptPad’s servers I think.
