So, after struggling with my computer in this topic. I decided to try a BIOS update.
I didn’t know it was so DAMN HARD to simply create a bootable USB for a BIOS update. Is it really that hard? All I need to do is update my BIOS, but the manufacturer of the computer (an Acer Aspire XC-780) only provides zip files.
@xahodo
Providing you can still get the zip file from Acer for the bios update, all bios updates I have did require the USB to be formatted with FAT32 unzip and extract the update to the FAT32 USB.
