Goshdarn!
I’m now about to build another Windows 10 machine - because I want to try an alternate feature for my new scooter… i.e. change the product number in firmware to a US product number (even though this scooter model’s not yet available in the USA) so that I can get 32 km/h instead of 25 km/h.
Why you may ask?
Well - I managed to fix my first Segway scooter, the shop I bought it from in July 2021 wanted $990 to fix it (3 months after warranty expiry, October/Novemer 2022). I used about $5 worth of connectors, about two bob’s worth of wire, about 4 hours of “on and off” elbow grease and I now have a working second scooter… Anyway I took it for a good long blat (did my back in, new one’s got shockies, old one doesn’t) and enjoyed cruise control AND 30 km/h…
Still waiting for a firmware update with cruise control for the newer scooter… But I’d also like 32 km/h (on the new scooter)…
So - I need a Windows 10 machine to change the product number… So I can get 32 kmh…
But do you think I can find the Windows 10 USB Boot stick I made a couple weeks ago? NO!!! FUDGEBAR!
Just realised… I’ve still got Bruv-in-law’s laptop here…
I can either
- use it to update the product number of the Segway e-scooter
- use it to create another Windows 10 install USB stick…
Goshdarn it again - I found a Ventoy Win10 stick I made yonks ago and it’s so much easier… I reckon I’m going to image that VENTOY stick again - I ever need to install Win10 again… So if I ever need to do this again : too easy! It’s installing - just using Win10 on it right now - but - I’ve left 256 GB free so I can install a Linux distro alongside and dual boot (probably ‘vanilla’ Ubuntu 22.04)… Handy having a Windows 10 system I guess…
And it’s Windows 22H1 I think… so less massive downloads of updates… If I’d found this Ventoy stick a couple weeks ago would have saved me a heap of time!
DAMN THAT WAS QUICK!
If only I’d had that Ventoy stick earlier! I’d have saved HOURS and HOURS
I’ve got a Windows 10 machine going and all the drivers are there and it’s just “working”… Got the scooter hacking thingie and paired via bluetooth from Windows 10 to the Segway scooter…
I’m having 2nd thoughts about increasing the speed limiter on it, all I really want is cruise control! But cruise control firmware not available in either the Android or iOS apps…
I chickened out and did not do the 32 km/h hack… 25 km/h on shared cycleways is plenty fast enough for me (despite constantly being overtaken by 100% pedal powered cyclists doing 35-45 km/h) - so I really have no need of Windows 10 - but it’s handy knowing I’ve got a machine I can use at a pinch, if it simply must be MS Windows!
All I really want is cruise control - there’s long stretches of pavement on my commute with no intersections - it’s a PITA to keep my thumb throttle depressed…
Also - I created an image of that Ventoy Stick in my Windows10 SOE folder on my NAS that I keep relevant documents and info for whenever I’m forced to (usually with threats) use a Windows 10 environment…
At least I have something to do Tuesday - install Ubuntu 22.04 alongside Windows 10 in a dual boot config…
