I have almost all the graphical files ready in SVG format. I am not sure what size I should use, or use it as SVG or PNG. Can someone guide me on how to build a cursor theme out of it ?
Can I bump this ? Character limit
I would look up the actual cursor files on my system and adjust my already existent files to the type, format and size the actual cursors are.
I tried that. Looks like it needs some script to convert them from PNG.
