Yes. Debian use ext4 filesystem. But if you can manage by writing a proper step by step guide, it will be very helpful. I think putting Gentoo and Debian in the bootloader will be same for Fedora and Debian.
I will wait for your return. ![]()
This still worries me.
Otherwise the USB worked as expected?
Thank Sheila!
Without seeing the output of parted -l I would never guessed btrfs to be in the gameâŚ
And on your link to Debian wiki:
So far, grub auto OS detection is flaky for btrfs,
explains why Fedora wasnât present in the menu.
I wasnât aware of this btrfs thing, as I told I have zero expereience with FedoraâŚ
That is the key. As I said earlier, having a btrfs OS control grub by installing it âafterâ MX Linux, I had no issues as it incorporated other installs into its grub. It is when you try to install the non-btrfs after the btrfs OS and have it control grub that issues arise.
If @Skywalker71 has already been using Fedora and does not want to install it again, we have to use a work around in order for Debian to show Fedora in its grub menu.
So I had to add those symlinks and copy a folder from @/boot on that subvolume to the EFI partition of MX Linux. Then MX gained back control of grub and added the entry in grub menu for Garuda OS.
Ok, now at the office. My partition layout is this:
The Debian is ext4 and I used Gparted to making the partition. My Debian os has only tty, no GUI so you should make big enough partition for it (at least 50GB would be fine). When youâre installing Debian donât let it install automatically to disk because it would then use the entire disk for Debian. Choose âsomething elseâ. There choose the partition you made with Gparted and use it as root. If the installer wonât let you go on without boot or efi partition you need to make one (just 512MiB fat32) and choose the small fat partition for boot.
After installation when the Debian reboots press tab/esc/F2/F10/F12 which one depends on your hardware and you get to the bios. Choose from there the Fedora boot partition (propably nvmeon1p1) and boot from there.
On Fedora remove the Debian boot partition with Gparted and check that your boot flag is as my on the picture (nvme0n1p1, fat32, /efi EFI and flags boot, esp). Then update-grub (or preferably sudo grub-mkconfig -o /boot/grub/grub.cfg) and follow the output of the update. It should say something like âusing OS-prober to find other systemsâ and find your Debian and add it to the boot menu. At this point you should have a boot menu with both OSes.
If you donât get the os-prober working let us know! If itâs not working / find Debian theres something wrong and probably just need to modify one config file.
I bet you cant make Debian the grub controlling distro, unless you have a separate /boot partition in Gentoo which is ext4
I dont think I know enough about Fedora to do that.
I think what you have to do is reinstall Fedora and make its /boot filesystem a separate partition with an ext4 filesystem., and leave its root partition as btrfs.
The reason for that is that grub ( or maybe os-prober) can not read a btrfs filesystem, so it cant access the grub.cfg file in Fedora if it is all on one btrfs partition . The workaround is to make /boot a separate partition and make it ext4.
Then , if you get that right, following my original steps should work.
But, I cant guarantee anything, because I dont understand Fedora.
and I donât want to. I have efi partition which is fat32 and boot is on Gentoo, btrfs.
pete@gentoo ~ $ sudo parted -l
Model: KINGSTON SNV2S500G (nvme)
Disk /dev/nvme0n1: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 2149MB 2147MB primary fat32 boot, esp
4 2149MB 10.5GB 8338MB primary linux-swap(v1) swap
2 10.5GB 416GB 405GB primary btrfs
3 416GB 500GB 84.2GB primary ext4
pete@gentoo / $ ls /
bin boot deja-dup dev dots efi etc home lib lib64 lost+found media mnt opt proc root run sbin sys temp tmp usr var work
pete@gentoo ~ $ ls -la /boot/
total 400404
drwxr-xr-x 1 root root 990 Oct 29 15:37 .
drwxr-xr-x 1 root root 302 Oct 11 10:15 ..
-rw-r--r-- 1 root root 0 Jun 16 14:28 .keep
-rw-r--r-- 1 root root 9413378 Oct 4 07:39 System.map-6.6.51-gentoo-dist
-rw-r--r-- 1 root root 9491377 Oct 26 12:43 System.map-6.6.57-gentoo-dist
-rw-r--r-- 1 root root 9491377 Oct 25 09:56 System.map-6.6.57-gentoo-dist.old
-rw-r--r-- 1 root root 9491563 Oct 29 15:37 System.map-6.6.58-gentoo-dist
-rw-r--r-- 1 root root 77312 Oct 29 15:32 amd-uc.img
-rw-r--r-- 1 root root 266814 Oct 4 07:39 config-6.6.51-gentoo-dist
-rw-r--r-- 1 root root 267709 Oct 26 12:43 config-6.6.57-gentoo-dist
-rw-r--r-- 1 root root 267709 Oct 25 09:56 config-6.6.57-gentoo-dist.old
-rw-r--r-- 1 root root 267712 Oct 29 15:37 config-6.6.58-gentoo-dist
drwxr-xr-x 1 root root 130 Oct 31 13:34 grub
-rw-r--r-- 1 root root 68048193 Oct 4 07:39 initramfs-6.6.51-gentoo-dist.img
-rw-r--r-- 1 root root 72263713 Oct 26 12:43 initramfs-6.6.57-gentoo-dist.img
-rw-r--r-- 1 root root 72263618 Oct 25 09:56 initramfs-6.6.57-gentoo-dist.img.old
-rw-r--r-- 1 root root 72286059 Oct 29 15:37 initramfs-6.6.58-gentoo-dist.img
-rw-r--r-- 1 root root 16665600 Oct 4 07:43 intel-uc.img
-rw-r--r-- 1 root root 15715312 Oct 4 07:39 vmlinuz-6.6.51-gentoo-dist
-rw-r--r-- 1 root root 17894384 Oct 26 12:43 vmlinuz-6.6.57-gentoo-dist
-rw-r--r-- 1 root root 17894384 Oct 25 09:56 vmlinuz-6.6.57-gentoo-dist.old
-rw-r--r-- 1 root root 17894384 Oct 29 15:37 vmlinuz-6.6.58-gentoo-dist
I was just making a point⌠I know you dont want that.
Do you use grub to boot Gentoo?
I am wondering how grub could read its grub.cfg file buried inside your btrfs filesystem?
yes, I know
I use grub, I have a EFI stub on my boot and everything works. I didnât even know grub doesnât work with btrfs. I just changed my SSD and decided to format it as btrfs a while ago and ddâed the old SSD to the new one and all is working.
edit: hereâs the grub info on my gentoo:
sys-boot/grub-2.12-r5::gentoo was built with the following:
USE=âdevice-mapper fonts mount nls sdl themes truetype -doc -efiemu -libzfs -secureboot (-test) -verify-sigâ ABI_X86=â(64)â GRUB_PLATFORMS=âefi-64 -coreboot -efi-32 -emu -ieee1275 (-loongson) -multiboot -pc -qemu (-qemu-mips) -uboot -xen -xen-32 -xen-pvhâ
CFLAGS=ââ
LDFLAGS=ââ
Have you tried update-grub since you changed to btrfs?
To be honest, I am not sure whether grub works properly with Btrfs or not. Reports are conflicting.
Dont panic. You can always use UEFI boot.
Yes, with sudo grub-mkconfig -o /boot/grub/grub.cfg
Only the USB 3 ports. USB 2 ports were out. But now if you ask me to do anything in Debian, I canât because as I have mentioned earlier, after the mess, I wiped the drive completely deleting the partitions and now I have installed Fedora 41. Itâs really nice. The first thing I noticed that the internet is faster than in Fedora 40.
I think you can install Davinci on Fedora?
Then install ocl-icd,
That seems to be the Fedora equivalent of mesa-opencl-icd.
Someone with Fedora expertise hopefully can confirm this.
Install Davinci on Fedora, then check your users membership.
Probably needs to be in groups âvideoâ and ârenderâ.
If you arenât member of those group, make itâŚ
Log-out, log-in to take effect the changed mebership.
Start DavinciâŚ
âŚfingers crossedâŚ
What if, I install Debian 12 first and then Fedora? What might be the outcome?
Thatâs what I was saying. As long as I was okay with Garuda controlling grub, no issue. I installed Garuda AFTER MX, it took control and it found MX to add to its grub menu. It is the reverse that does not work.
No, it is the issue of needing to install the btrfs after the other Linux. Fedora is capable of finding other Linux OS on the drives. But other Linux (like Debian) cannot gind Fedora due to use of subvolumes, without modifications.
I did not figure you wanted to reinstall Fedora, otherwise I would say, start over, install Debian and then install Fedora and let it control grub. At least that worked for me with MX & Garuda.
I tried if Debian could find Gentoo and it found it. From btrfs. Maybe grub had been updated to work with btrfs also.
and hereâs the same on Gentoo. Only difference seems to be how Debian mounts nvme0n1p1 to /boot/efi and Gentoo /efi
thatâs true, I tried that and it didnât find the snapshots but did find the gentoo os from btrfs
And did grub see the changes?.. can you see them in the edit menu?
