How to fix /etc/sudoers errors
Error 1
/etc/sudoers: syntax error near line 26 <<<
sudo: parse error in /etc/sudoers near line 26
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
Solution 1A
Edit:
On your terminal type:
pkexec nano /etc/sudoers
It will open the file and you can edit now. To save and exit the file, just press:
Ctrl+X
And it will ask you if you wanna save the file. So type: Y and >Enter. Done!!!
Solution 1B
we have to write -
pkexec visudo
And it will open the file and one need to change as previous if any made.
Then type Ctrl+X which will ask to save the file. So type: Y and Enter
Source : https://stackoverflow.com/questions/58195304/how-to-fix-etc-sudoers-syntax-error-near-line-number/58199760#58199760
Error 2
sudo: error in /etc/sudo.conf, line 0 while loading plugin 'sudoers_policy'
sudo: /usr/lib/sudo/sudoers.so must only be writable by owner
sudo: fatal error, unable to load plugins
:~$ pkexec su
Error executing command as another user: Not authorized
This incident has been reported
Solution 2
$ su root     #enter password
$ chmod 644 /usr/lib/sudo/sudoers.so
$ chown -R root /usr/lib/sudo
If not, you’ll have to startup in recovery mode, get write permission on your disk, and change the mode of that file. https://wiki.ubuntu.com/RecoveryMode
$ mount -o remount,rw /
Source : https://askubuntu.com/questions/637432/sudo-comes-up-with-an-error-cannot-run-anything-as-root
If above solutions doesn’t work, reinstall !
