For Ubuntu Desktop 22.04, with the ctrl + alt + t shortcut is opened the default terminal available.
Now Terminator was installed and with the same shorcut now Terminator is opened instead. I did do a research in Preferences for each one and does not exist a shortcut to define how to open each one. Only their respective internal shortcuts.
Through:
- Settings → Keyboard → Keyboard Shortcuts → View and Customize Shortcuts → Custom Shortcuts was defined ctrl + alt + y for
Terminatorand works.
But ctrl + alt + t remains for Terminator yet.
Through
- Settings → Keyboard → Keyboard Shortcuts → View and Customize Shortcuts → Launchers I can see the
Launch terminaloption defined with ctrl + alt + t but is not possible edit to indicate useTerminal
How to Fix this?
