How to unInstall/removed Popcorn Time on Fedora 32 and Other Linux Distributions
Can Tell Me How Can I Removed this full clean
Hi,
You’ll have to first tell us how did you install Popcorn time in the first place? The removal process corresponds to the installation procedure.
no idea man - when I used it (haven’t for a year or more now) - I just ran it as a portable app in a folder in my $HOME - uninstall was something like :
cd $POPCORNDIR ; rm -Rf *
I Follow This Way…Plz chack it
Hmm… I thought I had added the steps for removal.
Anyway… basically, you have to undo all the steps you did here:
Here are the commands… run carefully please:
Remove the popcorn time directory:
sudo rm -rf /opt/popcorntime
Remove the link:
sudo rm /usr/bin/Popcorn-Time
Remove the desktop file:
rm /usr/share/applications/popcorntime.desktop
Remove the catch files:
rm -rf ./.cache/Popcorn-Time
Remove the config files
rm -rf ./.config/Popcorn-Time
This should take care of it.
