How to use xdg-mime for default apps?
Edit: solved! I had Dolphin as my file manager, not thunar. I removed Dolphin and installed Thunar and all is well.
I’m trying to get mpv to open automatically when I click a .mkv file but no luck. I’m using Hyprland and file manager is thunar. Every time I click a video file like .mkv it opens a box and I need to select the application (and it has remember this box but I doesn’t remember my chosen application).
I don’t think this is Hyprland issue but correct me please if it is.. my latest try was to use xdg-mime as explained here How to use the command 'xdg-mime' (with examples)
But no luck. It seems my issue is not xdg-mime issue because it shows mpv. Sorry for the crappy pic!
You need to be careful setting things to run when you click on them.
It is a recipe for inadverdently running a trojan
I guess you trust mpv.
Well yes and it’s just my HTPC. I don’t have anything on it but some video files. It’s annoying to choose the program when I click a video file. I don’t see what’s the risk here. It’s normal for any os I think. You have preferred app for many file types. Somehow I just can’t get it to work with .mkv files
I solved the issue. Removed Dolphin and installed Thunar.
Edit: I didn’t see it was solved, plus misread the OP.
I’d set the default for all video.
xdg-mime default mpv.desktop video/*
After that try to run
xdg-open /path-to/a-valid/video
and see if it opens with mpv?
Then try from Thunar…
Good move. Thunar is reliable.
I use MPV as my default video player in Pop!_OS… i.e. when I double click a video in Nautilus - it opens in MPV… So many things to love about mpv… I love the way it always keeps the aspect ration when you resize the window, and you can drag the mpv window from anywhere - not just the title bar… and it’s light… I also use it to stream Free-To-Air from my Pi3 running TVHeadEnd, and both my IP camera rtsp streams
It wasn’t that way by default…
Nautilus :
I installed Thunar - and it’s even easier :
I guess what you’re asking - how to do it programmatically from a shell / CLI - I’ve never needed to do that…
I wonder would xclip help?
Yes, it didn’t work either way with Dolphin but with Thunar it opens automatically .mkv files with mpv.
Haven’t tried and no need to anymore.
Wayland with a wm still has some glitches. It’s just so much easier and quicker to install Wayland + Sway/Hyprland than Xorg and full DE on Gentoo.
