I suppose I'm lucky that I don't dual-boot using Grub!
I’ve been hearing about a lot of users who dual-boot Windows and GNU/Linux are unable to load GNU/Linux after installing the August cumulative Windows update. I saw this item in today’s (08/22/2024) CodeProject newsletter, and I suppose I’m lucky that I use rEFInd as my boot manager because I run my computers with SecureBoot enabled (I run Arch-based distributions because I’ve learned how to sign the kernel for them).
If you dual-boot Windows with GNU/Linux, this item may provide some useful information.
UPDATE!
It appears that Microsoft has offered a temporary work-around. I saw this item in today’s (8/26/2024) CodeProject newsletter. It includes steps to remove, and ‘fix’ the issue caused by the improper installation of an update to grub. If you’re being affected by this issue, read the linked item to learn how to get back into your affected computer.
I hope this helps,
Ernie
Ernie
I’ve been using Linux now for 10+ years (started with Ubuntu and now progressed to Debian 12) and have never dual booted with Windoze and never will. If I want to use Windoze (can’t think why these days) I’d buy a separate machine just for that purpose. The last thing I would want is to run the risk of infecting my daily driver!
Then this post is definitely not intended for you :slight_smile:. I’m simply trying to offer a bit of help to my fellow dual-boot-ers, even though I’m not affected by this calamity.
Ernie
apologies for disturbing your day :roll_eyes:
Hi Ernie
Thanks for the info.
Some people have blinkers on when replying.
No apology needed. You’re entitled to your opinion, and to express it. I simply wanted to make the purpose behind my post abundantly clear :slight_smile:
Ernie
Many people have very strong opinions about using the MSFT OS, and each has his/her reasons for them. When I say that everyone has a right to his/her opinions, and to express them, I mean it with no reservations/limitations. The only thing I object to, is trying to force anyone else to adhere to/support those opinions against their will. In the end, we should all agree to disagree, if we can’t find a better path, but we should all support each other’s rights to their own opinions too.
My2Cents,
Ernie
It’s easy to bash Microsoft and Windows in particular. I’m still amazed how well it works in general.
Hopefully it was an honest mistake and not an attempt to break about 0.05% of desktops. There aren’t that many dual booters out there I wouldn’t think. I am one of them and it didn’t seem to affect me. At least not that I know of.
I have a much bigger beef with Apple or probably more so with Apple fans with blinders on and don’t recognize certain things.
A news article today on It’sFoss: Oh, no! Windows Security Update Breaks Dual-Boot Linux Systems (itsfoss.com)
Microsoft is known for their signature, “my way or the highway” approach
If anyone has a “my way or the highway” approach it’s Apple. There isn’t a more closed software system on the planet. In my opinion.
My laptop is dual boot with Win 11 and Mint 21.3. Been a year now and so far no problems.
Then you may be among the fortunate dual-boot-ers. Linux Mint uses the Grub bootloader. Have you updated Windows, and did you install the August 2024 Cumulative Update yet? If so, you may be one of the fortunate users who didn’t get the Grub patch that is at the heart of all the current hubbub. The Grub patch isn’t supposed to be installed on computers that dual boot Windows and GNU/Linux using Grub, but it has been getting erroneously installed on some of them.
If you haven’t completed the update yet, you may be best served to read the linked item before updating Windows.
Ernie
Can’t argue with that, err… which way is the highway?
Edit: It’s ok my iphone told me.
Hi Paul
Did you send the link by mistake?
No think they are both about the same subject and need to be combined by one of the tech masters and his magic wand.
No prob, I’m sure the magic wand master will do the business.
perhaps the link provided some “traction”
:rofl:
No such luck… the magic wand and master got stuck in deep mud.
In my case I don’t have a problem because I’m using an older Dell tower with no secure boot option. So, I think I’m immune to this issue.
Got the feeling that most windows users dont get much choice updates forced without asking
Guessing you either don’t run SB or you employed the “don’t touch” registry patch MSFT published in time. I have one machine where I did not do that in time, and since then have run into issues with installing LMDE6 with SB enabled (following Mr. Wilcox’s astute guidelines here). It appears to install fine, and the Ventoy I use to install passes the “shim-signed” test, but when it’s time to reboot into LMDE it just won’t do it with SB enabled: “error: bad shim signature, you need to load the kernel first” which in my experience means a “shim-signed” signature failure. Also I’m not quite as bold as Ernie to employ rEFind instead of grub (there’s a lot about grub 2 I really hate) or to get Arch installs running with self-signed kernels. It is so much easier to install in a VM but I have had mixed luck with all the “free” (Hyper-V, VirtualBox) as opposed to “Pro” (VMware) type hypervisors.
