I wanted to install Xubuntu on my DigitalOcean droplet of 8GB RAM, 4vCPUs and 50 GB HDD but unfortunately not able to get success
I followed the below steps:-
XRDP installation
Tasksel installation
Installed Xubuntu desktop using Tasksel
restarted XRDP services
Now when I RDP this machine, I am not able to reach XUbuntu login screen. The system goes till xrdp screen. Can anyone help me please.
Akito
24 June 2021 12:27
2
Any logs you can provide?
Can you run the following and post its output here:
inxi -Fxmz
System: Kernel: 5.4.0-73-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Console: tty 0
Distro: Ubuntu 20.04.2 LTS (Focal Fossa)
Machine: Type: Kvm System: DigitalOcean product: Droplet v: 20171212 serial: <filter>
Mobo: N/A model: N/A serial: N/A BIOS: DigitalOcean v: 20171212 date: 12/12/2017
Memory: RAM: total: 7.78 GiB used: 651.4 MiB (8.2%)
Array-1: capacity: 8 GiB slots: 1 EC: Multi-bit ECC max module size: 8 GiB note: est.
Device-1: DIMM 0 size: 8 GiB speed: type: RAM
CPU: Topology: Quad Core model: DO-Premium-Intel bits: 64 type: MCP arch: Skylake rev: 4 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19953
Speed: 2494 MHz min/max: N/A Core speeds (MHz): 1: 2494 2: 2494 3: 2494 4: 2494
Graphics: Device-1: Red Hat QXL paravirtual graphic card driver: N/A bus ID: 00:02.0
Display: server: X.org 1.20.9 driver: N/A tty: 168x44
Message: Advanced graphics data unavailable in console for root.
Audio: Message: No Device data found.
Network: Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: Red Hat Qemu virtual machine type: network bridge driver: N/A
port: c080 bus ID: 00:01.3
Device-2: Red Hat Virtio network driver: virtio-pci v: 1 port: c0c0 bus ID: 00:03.0
IF: eth0 state: up speed: -1 duplex: unknown mac: <filter>
Device-3: Red Hat Virtio network driver: virtio-pci v: 1 port: c0e0 bus ID: 00:04.0
IF: eth1 state: up speed: -1 duplex: unknown mac: <filter>
Drives: Local Storage: total: 160.00 GiB used: 4.81 GiB (3.0%)
ID-1: /dev/vda model: N/A size: 160.00 GiB
Partition: ID-1: / size: 154.90 GiB used: 4.80 GiB (3.1%) fs: ext4 dev: /dev/vda1
Sensors: Message: No sensors data was found. Is sensors configured?
Info: Processes: 141 Uptime: 27m Init: systemd runlevel: 5 Compilers: gcc: N/A Shell: bash v: 5.0.17 inxi: 3.0.38
Please suggest next steps
Akito
24 June 2021 16:08
5
grep -v 'DEBUG' /var/log/xrdp.log
grep -v 'DEBUG' /var/log/xrdp-sesman.log
[20210624-15:10:24] [INFO ] address [0.0.0.0] port [3389] mode 1
[20210624-15:10:24] [INFO ] listening to port 3389 on 0.0.0.0
[20210624-15:10:24] [INFO ] xrdp_listen_pp done
[20210624-15:10:26] [INFO ] starting xrdp with pid 23731
[20210624-15:10:26] [INFO ] address [0.0.0.0] port [3389] mode 1
[20210624-15:10:26] [INFO ] listening to port 3389 on 0.0.0.0
[20210624-15:10:26] [INFO ] xrdp_listen_pp done
[20210624-15:30:34] [INFO ] address [0.0.0.0] port [3389] mode 1
[20210624-15:30:34] [INFO ] listening to port 3389 on 0.0.0.0
[20210624-15:30:34] [INFO ] xrdp_listen_pp done
[20210624-15:30:36] [INFO ] starting xrdp with pid 50947
[20210624-15:30:36] [INFO ] address [0.0.0.0] port [3389] mode 1
[20210624-15:30:36] [INFO ] listening to port 3389 on 0.0.0.0
[20210624-15:30:36] [INFO ] xrdp_listen_pp done
[20210624-15:31:06] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:103.211.54.245 port 54062
[20210624-15:31:06] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:31:06] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:31:06] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:31:08] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:103.211.54.245 port 54064
[20210624-15:31:08] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:31:08] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:31:08] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:31:08] [INFO ] connected client computer name: PEEYUSH-PC-BD-0
[20210624-15:31:08] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20210624-15:31:08] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20210624-15:31:08] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20210624-15:31:08] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20210624-15:31:09] [INFO ] Non-TLS connection established from ::ffff:103.211.54.245 port 54064: encrypted with standard RDP security
[20210624-15:31:10] [INFO ] Cannot find keymap file /etc/xrdp/km-00004009.ini
[20210624-15:31:10] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
[20210624-15:31:10] [WARN ] local keymap file for 0x00004009 found and doesn't match built in keymap, using local keymap file
[20210624-15:31:23] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20210624-15:31:23] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20210624-15:31:23] [INFO ] lib_mod_log_peer: xrdp_pid=51046 connected to X11rdp_pid=51089 X11rdp_uid=0 X11rdp_gid=0 client_ip=::ffff:103.211.54.245 client_port=54064
[20210624-15:42:46] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:165.227.136.212 port 61194
[20210624-15:42:46] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:42:46] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:42:46] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:44:28] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:165.227.136.212 port 52171
[20210624-15:44:28] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:44:28] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:44:28] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:46:12] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:165.227.136.212 port 59508
[20210624-15:46:12] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:46:12] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:46:12] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:47:54] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:165.227.136.212 port 50481
[20210624-15:47:54] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-15:47:54] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-15:47:54] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-16:24:57] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:167.172.31.96 port 61000
[20210624-16:24:57] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-16:24:57] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-16:24:57] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-16:27:05] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:45.76.125.37 port 51585
[20210624-16:27:05] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210624-16:27:05] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210624-16:27:05] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210624-15:10:24] [INFO ] starting xrdp-sesman with pid 23721
[20210624-15:10:24] [INFO ] listening to port 3350 on 127.0.0.1
[20210624-15:30:34] [INFO ] shutting down sesman 1
[20210624-15:30:34] [INFO ] starting xrdp-sesman with pid 50936
[20210624-15:30:34] [INFO ] listening to port 3350 on 127.0.0.1
[20210624-15:31:23] [INFO ] A connection received from ::1 port 55762
[20210624-15:31:23] [INFO ] ++ created session (access granted): username root, ip ::ffff:103.211.54.245:54064 - socket: 12
[20210624-15:31:23] [INFO ] starting Xorg session...
[20210624-15:31:23] [INFO ] calling auth_start_session from pid 51083
[20210624-15:31:23] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210624-15:31:24] [CORE ] waiting for window manager (pid 51088) to exit
[20210624-15:31:24] [CORE ] window manager (pid 51088) did exit, cleaning up session
[20210624-15:31:24] [INFO ] calling auth_stop_session and auth_end from pid 51083
[20210624-15:31:24] [INFO ] ++ terminated session: username root, display :10.0, session_pid 51083, ip ::ffff:103.211.54.245:54064 - socket: 12
Akito
24 June 2021 17:30
8
Read through these posts and apply each solution or workaround found, one by one, starting with the least invasive one, until one helped:
opened 09:06PM - 17 Sep 19 UTC
closed 04:45AM - 09 Oct 19 UTC
Hi
I have xrdp installed on both RH 7.6 and 7.7 both are showing the same be… havior. Can you please suggest if I have to make any config changes for this to work?
I do not have file on Redhat : /etc/xrdp/startwm.sh
tigervnc.x86_64 1.8.0-17.el7 @rhel_7Server_x64_localrepo
xrdp.x86_64 1:0.9.11-1.el7 @EPEL7_x64_localrepo
Logs : xrdp-sesman.log
[20190917-14:00:38] [INFO ] shutting down sesman 1
[20190917-14:00:38] [DEBUG] Closed socket 7 (AF_INET 127.0.0.1:3350)
[20190917-14:00:38] [DEBUG] libscp initialized
[20190917-14:00:38] [INFO ] starting xrdp-sesman with pid 2577
[20190917-14:00:38] [INFO ] listening to port 3350 on 127.0.0.1
[20190917-14:00:52] [INFO ] A connection received from 127.0.0.1 port 50236
[20190917-14:00:52] [INFO ] ++ created session (access granted): username user, ip **.***.**.***:53246 - socket: 12
[20190917-14:00:52] [INFO ] starting Xvnc session...
[20190917-14:00:52] [DEBUG] Closed socket 9 (AF_INET 0.0.0.0:5910)
[20190917-14:00:52] [DEBUG] Closed socket 9 (AF_INET 0.0.0.0:0)
[20190917-14:00:52] [DEBUG] Closed socket 9 (AF_INET 0.0.0.0:5911)
[20190917-14:00:52] [DEBUG] Closed socket 9 (AF_INET 0.0.0.0:6011)
[20190917-14:00:52] [DEBUG] Closed socket 9 (AF_INET 0.0.0.0:6211)
[20190917-14:00:52] [DEBUG] Closed socket 8 (AF_INET 127.0.0.1:3350)
[20190917-14:00:52] [INFO ] calling auth_start_session from pid 2715
[20190917-14:00:52] [DEBUG] Closed socket 7 (AF_INET 127.0.0.1:3350)
[20190917-14:00:52] [INFO ] Xvnc :11 -auth .Xauthority -geometry 3840x2174 -depth 24 -rfbauth /home/user/.vnc/sesman_passwd-user@rpub1234.user.company.com:11 -bs -nolisten tcp -localhost -dpi 96
[20190917-14:00:52] [CORE ] waiting for window manager (pid 2717) to exit
[20190917-14:00:53] [CORE ] window manager (pid 2717) did exit, cleaning up session
[20190917-14:00:53] [INFO ] calling auth_stop_session and auth_end from pid 2715
[20190917-14:00:53] [DEBUG] cleanup_sockets:
[20190917-14:00:53] [INFO ] ++ terminated session: username user, display :11.0, session_pid 2715, ip **.***.**.***:53246 - socket: 1
linux, remote-desktop
arch-linux, xrdp, rdp
https://bbs.archlinux.org/viewtopic.php?id=265922
https://bugzilla.redhat.com/show_bug.cgi?id=1575792
I was able to connect via X2go client
