Interim Computer Museum
Just dropped into the article and thought about some of our more experianced users who mention using older boxes
Ok I followed the link got on the a dec pdp 11 login screen then could not remember any unix commands to get further, bet some of your do ….
I tried… it wants menue… not menu as login name
But then it asks for a password?
No idea on password, I tried it yesterday when I posted and got the menu correctly, now says timeout, tried menue and that as you say needs password.
Try later ?
Perhaps a fault at their end.
Dont know enough Unix to suggest more.
The idea looked great
Welcome to the forum @marrycharli1.
Thanks for your post and I hope you will consider to help out when you can.
Take care,
Howard
Might temporarily be experiencing outages, when I went to try it right now it “failed to load resource” and “unable to load module resource”.
But sounds pretty interesting; thanks for sharing!
