I’ve been experimenting with combining command on one line. I’ve found && and ; give the same results. Are these interchangeable or is is there some subtle difference between the two?
Posted by Steve in Linux Users Group.
There is a BIG difference between the two. If you use && and if the first command doesn’t run successfully, the second command won’t run.
With ; there is no such thing. The second command will run irrespective whether the previous command succeeded or not.
Very good tp know the difference between && and ;
Thank you
Wicklowham
I drew an infographic explaining that.
Usually, I share the link only if you register on my mailing list. But for itsfoss.community members, here is a direct link to download the PDF
https://drive.google.com/file/d/113ASfatibe4UaX15r_4haumo3BPdluwp
If you want to share that with your friends, please point them to https://www.yesik.it/SHELL10 – or ask them to register on https://itsfoss.community
