Hello Friends
Sorry for the huge delay …
Daniel @dbauthor
Manuel, I am curious: what would you use this list for? (It would contain tens of thousands of commands.)
Wooh a lot …
For:
- academic purposes
- researching purposes too
and consider the following scenario:
- You need to resolve a network situation, so if you have the complete and official list of the commands about the network category. Then is possible have many options to find the solution. Consider if “M” command is better than “B” command. I hope you see my point.
Do you just want to read through it?
Yes, it to have in hand a bigger range of commands as tools to resolve something. And because you are an author: consider write an appendix for many categories about commands. For example Appendix A for Network, Appendix B for Encryption and so go on … from where you can do a comparison if each appendixes have the correct set of commands?
Would you use it as a reference to find commands of a certain type?
Yes, like a toolbox
Were you looking for a specific command recently and couldn’t find one? Something else?
Not really, but I thought that situation.
I’m just wondering what problem you’re trying to solve with a gigantic list.
Have a central reference.
Something similar than in Java where there are official repositories for dependencies:
Maybe there’s a better solution than a list.
Good point too
Rosika
The book follows the structure described. It should come close to what Manuel is looking for. But in German
Agree, but each book is a different research by each author … perhaps some book covers some commands not covered in other and vice versa
Abhishek
Thanks for the links
You need to have a CLI commands section on your FOSS home page.
+1 it would be a good beginning to start a kind of central standard reference ..
Consider: How was “Filesystem Hierarchy Standard” created?
stillnoobish
Huge thanks for that link
