I just installed Mint on an old Lenovo All-in-One PC. Neofetch results are as follows;
neofetch
...-:::::-... stark@shawshank
.-MMMMMMMMMMMMMMM-. ---------------
.-MMMM`..-:::::::-..`MMMM-. OS: Linux Mint 20.2 x86_64
.:MMMM.:MMMMMMMMMMMMMMM:.MMMM:. Host: IdeaCentre B300 10051 Lenovo
-MMM-M---MMMMMMMMMMMMMMMMMMM.MMM- Kernel: 5.4.0-74-generic
`:MMM:MM` :MMMM:....::-...-MMMM:MMM:` Uptime: 8 mins
:MMM:MMM` :MM:` `` `` `:MMM:MMM: Packages: 1998 (dpkg)
.MMM.MMMM` :MM. -MM. .MM- `MMMM.MMM. Shell: bash 5.0.17
:MMM:MMMM` :MM. -MM- .MM: `MMMM-MMM: Resolution: 1024x768
:MMM:MMMM` :MM. -MM- .MM: `MMMM:MMM: DE: Cinnamon
:MMM:MMMM` :MM. -MM- .MM: `MMMM-MMM: WM: Mutter (Muffin)
.MMM.MMMM` :MM:--:MM:--:MM: `MMMM.MMM. WM Theme: Mint-Y-Dark (Mint-Y)
:MMM:MMM- `-MMMMMMMMMMMM-` -MMM-MMM: Theme: Mint-Y [GTK2/3]
:MMM:MMM:` `:MMM:MMM: Icons: Mint-Y [GTK2/3]
.MMM.MMMM:--------------:MMMM.MMM. Terminal: gnome-terminal
'-MMMM.-MMMMMMMMMMMMMMM-.MMMM-' CPU: Intel Core 2 Duo E7500 (2) @ 2.933GHz
'.-MMMM``--:::::--``MMMM-.' GPU: Intel 4 Series Chipset
'-MMMMMMMMMMMMM-' Memory: 1149MiB / 1952MiB
stark@shawshank:~$ inxi -Fxz
System:
Kernel: 5.4.0-91-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 5.0.7 Distro: Linux Mint 20.2 Uma
base: Ubuntu 20.04 focal
Machine:
Type: Desktop System: LENOVO product: IdeaCentre B300 10051 v: Lenovo
serial: <filter>
Mobo: LENOVO model: N/A serial: <filter> BIOS: LENOVO v: D4KT16AUS
date: 12/29/2010
CPU:
Topology: Dual Core model: Intel Core2 Duo E7500 bits: 64 type: MCP
arch: Penryn rev: A L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 11703
Speed: 1596 MHz min/max: 1600/2933 MHz Core speeds (MHz): 1: 1596 2: 1596
Graphics:
Device-1: Intel 4 Series Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.11 driver: modesetting
unloaded: fbdev,vesa resolution: 1024x768~60Hz
OpenGL: renderer: Mesa DRI Intel G41 (ELK) v: 2.1 Mesa 21.0.3
direct render: Yes
Audio:
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: Z-Star Micro type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-8.2:4
Sound Server: ALSA v: k5.4.0-91-generic
Network:
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: e800 bus ID: 01:00.0
IF: ens32 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Lenovo
driver: ath9k v: kernel port: e800 bus ID: 02:00.0
IF: wls33 state: up mac: <filter>
Drives:
Local Storage: total: 119.24 GiB used: 8.66 GiB (7.3%)
ID-1: /dev/sda model: 128GB SSD size: 119.24 GiB
Partition:
ID-1: / size: 26.86 GiB used: 8.66 GiB (32.2%) fs: ext4 dev: /dev/sda6
Sensors:
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 183 Uptime: 34m Memory: 1.91 GiB used: 1.55 GiB (81.4%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17
inxi: 3.0.38
stark@shawshank:~$ xrandr
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192
VGA-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
1920x1080 (0x114) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
stark@shawshank:~$ lspci -k | grep -A 2 -i "VGA"
00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
Subsystem: Lenovo 4 Series Chipset Integrated Graphics Controller
Kernel driver in use: i915
stark@shawshank:~$ for p in /sys/class/drm/*/status; do con=${p%/status}; echo -n "${con#*/card?-}: "; cat $p; done
VGA-1: connected
My display settings are showing Unknown VGA-1 and the display is too big with 1024x768. How to solve this issue and have decent resolution?
