I posted a note with a similar subject line recently and, following the advice I received, upgraded my system and the application in question. Now I am running Linux Mint 19.2 Tina, desktop Cinnamon 4.2.4, and Libreoffice 6.3.1.2.
Calc freezes very often. Not at regular intervals; it can work happily for a couple of days and then freeze several times in a couple of hours (now is one such period). It may seem to be in response to my pressing two keys in very close succession (for example Shift+DownArrow and then Shift+UpArrow), but this wasnât the case the last time around.
And itâs not generally due to lack of memory. On some occasions System Monitor tells me that a third of the memory is free and stays free. Although on others LibreOffice freezes first and then proceeds to slowly claim all the remaining free memory, then the swap as well, eventually slowing down the entire system.
Is there anything I can do to diagnose the situation when it occurs? Or is reverting to LibreOffice 6.1 (which didnât behave in this way, I seem to I remember) the only way to get some work done?
Are you running anything else at the same time and do you have Java enabled ? If you have Java enabled disable it. The latest version 6.3.2.2 not 6.3.1.2 so you could try an upgrade again. I canât recall any other have the problem, but a google search might help with that for you.
Sorry canât think of anything else at the moment
in regards to your diagnosis question, mint 18.3 has a system log viewer (i would imagine 19 has the same or similar). in the menu i just type âlogâ and it shows up as âSystem Logâ. in the left panel âsyslogâ is listed. clicking on that gives you a look at the system log before you launched it (it does not update in real time), but you need to scroll all the way down to the bottom to see the most recent entries.
Thatâs good that you have disabled that. I still canât find another with this problem after doing a search or looking back through my notes to see if I had come across it before. Perhaps the best place for you to go to now is here; https://ask.libreoffice.org/en/questions/ which is one of the main pages for Libre Office
Firefox, most of the time.
I use LibreOffice 6.3.3.2 now. I disabled Java in LibreOffice; I also switched off Summary on search (under Calc|View|Window), because on some occasions the freezing followed a Find & Replace in a large spreadsheet (https://bugs.documentfoundation.org/show_bug.cgi?id=79422).
Problem still obtains, at irregular intervals; not at all on some days, half a dozen times on others.
Thing is, someone has tried doing that and received a discouraging reply (https://ask.libreoffice.org/en/question/88786/libreoffice-calc-hangs-randomly/). The worst thing in my situation is that I, like te poster there, canât say much more than â⌠hangs randomlyâ: the circumstances can be very different (last time it happened, about an hour ago, even /var/log/syslog seems not to have noticed anything).
I uninstalled 6.3 and went back to 6.2.8.2, and all was well for a fortnight, until â a quarter of an hour ago â LibreOffice froze again. This time it was Writer, not Calc, that I was using at the time. I looked at System Monitor â the CPU wasnât very busy and the memory was not full. Looked at /var/log/syslog â nothing remarkable there either.
I think Iâll try another downgrade; I have 6.1.5.2 handy.
