Can anyone show me how to get a terminal window icon into the panel of a Cinnamon desktop.?
Is Cinnamon able to save the X session on shut down and restore it at boot?
If you go into the menu, locate the Terminal application (probably under Administration or such like) and right click, it offers you the option to âadd to panelâ. The change is permanent (i.e. will be retained at next boot).
I too like to have the terminal available from the panel.
Hi Neville,
I am running Mint Cinnamon and the terminal icon is already in the panel. But if you bring up the menu and search for terminal, then right click on the name, you should get some options. Add to desktop, add to panel, etc.
I assume âX sessionâ is terminal session. I always copy it to a text file if I want to save it before I re-boot if I want to look at it later.
Not much help ⊠sorry.
Thank you, that is easy.
Thanks Howard. I should have known that.
In Xfce there is a setting to save the whole desktop when you shutdown. Then when you boot and login, all your windows are there on the screen, and in the same state as when you logged out.
I dont think Cinnamon has that. Its called saving your Xsession. Mint may not even be X11, it may be Wayland for all I know?
I just press ctrl-alt-T.
It works in most DE, I think it should work on Cinnamon too. If it works, certainly the quickest way to launch a terminal.
Hey, it works like magic.
Perhaps I need to learn a few keyboard shortcuts.
Itâs Super-T in Pop-OS!
I remember that caused you an issue a while back. Something about starting all kinds of stuff at restart time and there was some sort of issue. I think you had to get rid of something that was running before it would restore you last window arrangement. I forget the details now.
Can you explain Super?
Yes it slows up the boot. I put up with it. For some reason much worse in Void/Xfce than in MX or Gentoo.
Itâs labelled as the âWindowsâ key on the keyboard. But in Linux it would be weird to call it âWindowsâ, so itâs the âSuperâ - I think. ![]()
Edit:
I remember the name âSuperâ from the time I tried XFCE. ![]()
Now, in MATE on my Debian it is called âMod4â.
Just tried to set Super-T to launch a terminal, it shows as âMod4+Tâ in the shortcut manager.
@kovacslt ,
Thank you for Super explanation.
I am in VoidXfce at moment . Ctrl Alt T works on the main screen, and in a VM.
Super T does not work.
I have to remember which distro Iâm on. For example Pop_OS! uses Super-T, but Ubuntu uses Ctrl-Alt-T I believe. I donât bounce around a ton, but enough to confuse me.
This shortcut easily customizable. Why donât you set it to be the same across all your distros? You donât have to use the defaults everywhere.
Doesnât work for me on Pop!_OS (Super+T)
Not that I need it - I have it on my dock (the default gnome âpanelâ in Pop!_OS but configured as an autohide bottom dock, instead of âextendedâ panel) - and just tried super (sometimes called âmetaâ) + T on my Ubuntu 23.04 thinkpad, and doesnât do it there either - but - I also have a dock (Ubuntu Gnome 3 dock) there with terminal on itâŠ
And thatâs the exact same way I fire up a terminal on MacOS too - iTerm2 in the dockâŠ
Hmmm. I have an Ubuntu 23.04 VM and it uses the standard Ctrl-Alt-T.
My Pop_OS! uses Super-T. I checked in Settings > Keyboard > View and Customize Shortcuts > Launch Terminal. Here it shows Super-T. I donât know for a fact that is the default. Maybe I customized it at some point in the past few months.
I customised my Pop!_OS so that Super+C and Super+V would do copy and paste, respectively, for consistency across MacOs and LinuxâŠ
It was pointless really - as for some reason, Synergy doesnât send Super to MacOS synergy clientsâŠ
Iâve just tried to google solutions (send Super to MacOS clients) and the only hit in the synergy forums is a link to Symless Zendesk, and I donât have an account there - so much for my Synergy Pro license!
I fixed my Synergy issuesâŠ
I thought I had to modify âModifier keysâ on the server settings⊠Doh!
No : âModifier keysâ for each Mac client. So Iâve changed it on the two Mac clients (in the server config) ![]()
Shift = Shift
Ctrl = Ctrl
Alt = Super
Meta = Alt
Super = Super
Now I can use âALTâ for the Command button, but I can also use SuperâŠ
So âAlt+Câ does the clipboard and âAlt+Vâ pastes, as does Super+V, and Shift + Super (or Alt) + 4 does screenshot with marquee selectâŠ
Cooking with GAS!
Sounds a little confusing. Hope it works well for you.
