Hmm…, that´s strange. When doing the same in Lubuntu sensors DID recognize my fan. So theoretically it can be done.
I´m a bit at a loss here. Can anyone help me
Thanks a lot in advance.
Many greetings from Rosika
Yesterday evening I shut down my system and today I started it again (cold start of course) and it seems reboot (or cold start?) was needed to take effect as far as sensors in its entirety is concerned.
Here´s my today´s output:
sensors
it8772-isa-0a30
Adapter: ISA adapter
in0: 2.23 V (min = +2.81 V, max = +3.06 V) ALARM
in1: 2.23 V (min = +0.76 V, max = +2.29 V)
in2: 1.98 V (min = +2.87 V, max = +2.87 V) ALARM
+3.3V: 3.29 V (min = +5.90 V, max = +2.90 V) ALARM
in4: 3.06 V (min = +1.33 V, max = +1.70 V) ALARM
in5: 3.06 V (min = +0.00 V, max = +3.05 V) ALARM
in6: 2.23 V (min = +3.05 V, max = +2.48 V) ALARM
3VSB: 3.26 V (min = +0.00 V, max = +5.54 V)
Vbat: 3.17 V
fan2: 1534 RPM (min = 46 RPM)
temp1: -70.0°C (low = -2.0°C, high = +86.0°C) sensor = disabled
temp2: +26.0°C (low = -1.0°C, high = +127.0°C) sensor = thermal diode
temp3: -66.0°C (low = -41.0°C, high = +119.0°C) ALARM sensor = Intel PECI
intrusion0: ALARM
acpitz-acpi-0
Adapter: ACPI interface
temp1: +27.8°C (crit = +92.0°C)
temp2: +29.8°C (crit = +92.0°C)
coretemp-isa-0000
Package id 0: +28.0°C (high = +87.0°C, crit = +91.0°C)
Core 0: +28.0°C (high = +87.0°C, crit = +91.0°C)
Core 1: +27.0°C (high = +87.0°C, crit = +91.0°C)
On an irregular basis I use the watch command which now works as desired:
