Look I Made a Funny!
Perfect example of the way Arch drives newbies away from Linux.
Been using Linux for 30 years, and Arch is very likely to be my next OS. I’m fed up with these buggy Manjaro rolling releases.
Arch has come a long way, and it’s far easier to install now.
you don’t use Arch BTW - it uses you :smiley:
As a rolling release, Void is superior to Arch in stability, in range of available packages, and in ease of install. Void documentation is adequate…not quite as extensive as Arch, but it does not need to be.
Void can use .deb files, as well as its own xbps packages.
I asked the UNIX gods about the ultimate answer to life the Universe and everything, and fully expected forty two as the answer - I was wrong in my anticipaton : but I wasn’t disappointed :
Rock In Peace - Ozzy Osbourne 1948-2025
Another hitchhiker fan !
They dont make books like that any more…
Larry the Cow knows
Apophenia. In statistics it is called a type 1 error
