Making a Nostalgic Configuration of NetBSD in Virt-Manager
Making a nostalgic configuration of NetBSD in virt-manager - Part1
I grew up with Berkeley Unix ( 4.2BSD on a Motorola 68010 processor in a mini-computer).
This is a bit of a nostalgia trip. The nearest thing I can find to that today on a PC is NetBSD. The oldest PC Unix is 386BSD. It can be found in archives, but is not distributed today. So NetBSD is the oldest surviving PC Unix, closlely followed by FreeBSD, (but FreeBSD has morphed). NetBSD is the closest thing to original Berkeley Unix.
NetBSD downloads are available here
https://www.netbsd.org/
It is available for an amazing range of hardware.
Install
I used NetBSD-10.0-amd64.iso and installed it in virt-manager (QEMU/KVM)a running in a Void Linux host.
The install is a simple stepwise process with dialog screens. You can see all the steps here
https://www.netbsd.org/docs/guide/en/chap-exinst.html#exinst-system-configuration
I did a full install to a virtual disk, but I neglected to configure the network in the configuration menu. That led to some difficulties later on .
The install is fast, and when finished you reboot and get a display like the following
Choose [1] and it boots to a console login
Then login and you get a shell prompt
That is an sh shell prompt. The other options are csh and zsh. That is right, no bash although sh is a good approximation. For a real Berkekely experience I should be using ‘csh’ as the interactive shell.
There is an X window system, called CTWM, which is a modified TWM. You can start it with startx
So you get a terminal window ( a uxterm with no scrollbar) and there are 4 workspaces ( lower right). There is a menu that comes with a right click on background.
That is it, fairly basic, no taskbar or icons. I can work with that.
Configure network
Now lets see if we can communicate with it.
First shock… it does not have ip command… it uses ifconfig
That interface vioif0 is the bridge to the virt-manager host.
I chose the virti0 device model in virt-manager for the NIC . The default e1000 did not work with NetBSD for me.
Notice that vioif0 has no IP address. Most Linuxes installed in virt-manager automatically setup an IP address for the virtual machine… my NetBSD does not… because I did not ask for network setup at install time.
So, having neglected to do it at install time, I have to now do it by hand.
It needs to have dhcpcd running. It is there
$which dhcpcd
/sbin/dhcpcd
but not running
ps ax | grep dhcp
nothing
So, how do I start a daemon in NetBSD?
That starts dhcpcd for the current session. Notice vioif0 now has an IP number 192.168.122.160. I can ping the host.
To make it start at boot I have to make some settings in /etc/rc.conf
ifconfig_vioif0="up"
dhcpcd=YES
Now, reboot and test
OK, the interface is up and has an IP number.
Check the routing with route show
All OK.
For those who might want to bring the interface up with a static IP the commandds are
ifconfig vioif0 inet 192.168.122.99 submask 255.255.255.0
route add default 192.168.122.1
I dont recommend it.
Learn from my oversight… when you install NetBSD configure the network at install time.
Please can I have a scrollbar on my Xterm
My original access to Berkekey Unix was an alphanumeric terminal… ie a CRT screen that displayed characters , but not graphics. So, no Window Manager, only one window which displayed the last 24 lines.
So today’s NetBSD with a Window Manager is a luxury by comparison… I can have multiple windows, multiple workspaces, the only thing I miss is the Xterm does not have a scrollbar.
That is easily fixed.
The file that controls Xterm layout is called .Xresources. It needs to be in your home directory.
I have a generic .Xresources file . It has a lot of lines about colours , followed by
Put that in the home directory and reboot.
You can see the scrollbar on the right
It slides with middle button and steps up with right button or down with left button. It keeps 4096 lines.
I can live with that.
What is the filesystem like
NetBSD uses by default the Berkeley Fast File System (FFS)
FFS is basis of Linux ext filesystems. Linux can read files from an FFS filesystem if it has kernel modules supporting UFS. UFS is the original Unix filesystem, FFS is a BSD derivative of UFS.
Lets have a look at my root filesystem
First notable difference there is no boot directory. The NetBSD binary is called netbsd, and it is in the root directory.. It is 28Mb. Not large . By comparison Void Linux is 124Mb for the initramfs and 13Mb for vmlinuz. BSD does not use an initramfs. Its boot mechanism is simpler.
There is a file boot which is binary, and another file boot.cfg
which seems to be instructions for grub. ( Like /etc/default/grub in Linux)
There is another directory /kern
which seems to contain kernel-relevant stuff that would normally be in /etc
Otherwise , the structure seems to be fairly standard, and would be familiar to Linux users. The X11 code is in /usr/X11R7.
The search path is a little unusual
That PATH definition is in ~/.profile
In /usr/mdec there is a collection of boot files for both efi and mbr.
(continued in next reply)
Making a nostalgic configuration of NetBSD in virt-manager - Part2
The package system
The original Berkekey Unix did not have a package system. You got what came with the distribution. There was internet, but it only supported email and ftp. So one could download source code ( Fortran or C usually) from sites like Netlib, and compile it , like in Gentoo today only without the help of portage.
So packaging in NetBSD is not part of my nostalgic journey. It is newfangled stuff.
The NetBSD package installing software is described here
https://www.netbsd.org/docs/guide/en/chap-boot.html#chap-boot-pkgsrc
There are 19980 packages available as binaries.
You can also build packages from source.
https://www.netbsd.org/docs/pkgsrc/using.html
The package facility is called pkgsrc, but that is not a command… the commands are pkg_add, pkg_delete, pkg_info, …
Using binary packages
One has to tell NetBSD where the package server is. In a Debian-based Linux you would define that in /etc/apt/sources.list. NetBSD does it differently. It defines an environment variable called PKG_PATH
Well, I followed the book, but that did not work
So I can ping the site. What could be wrong? Have a look with the browser
Oh, stupid me, those names in capitals OPSYS/ARCH/VERSIONS are generics. I need NetBSD/x86_64/10.0.
Well that is progress. It found the site. Packages are .tgz files. Looks like I need to do it as root , or maybe make some directories , like usr/pkg
OK, it works as root.
So NetBSD is like FreeBSD, in that it keeps added packages in a separate directory. FreeBSD uses /usr/local but NetBSD uses /usr/pkg. The merit of this is that packages do not interfere with system upgrades.
pkgin is the recommended tool for updating packages, and can also be used for searching
Yes, NetBSD has the package a2ps used for print formatting. It is not installed.
Quite a bit of fuss, but it did the install.
To delete a package pkgin remove PKGNAME or pkg_delete PKGNAME.
Version control seems to be a matter of setting the PKG_PATH environment variable.
One last thing, the definition of PKG_PATH needs to be added to the file ~/.profile, for each user including root, so that it is defined at each login.
Building packages from source code
If you build a package from source, you can compile code and install it the same way you would for a program written by yourself. There are no restrictions.
Most distros provide a procedure for dealing with source code packages in a standardised way. In NetBSD the build utility for source code is called pkgsrc.
https://www.netbsd.org/docs/software/packages.html
It supports most BSD distros, and Linux, ( ie you can use pkgsrc in distros other than NetBSD). It is different to the Gentoo portage system or the FreeBSD ports system.
To get pkgsrc for the first time one can download a tar file with ftp and unpack it in the /usr directory.
# ftp ftp://ftp.NetBSD.org/pub/pkgsrc/pkgsrc-2025Q2/pkgsrc.tar.gz
# tar -xvf pkgsrc.tar.gz -C /usr
This creates a directory called /usr/pkgsrc, which is where all the source code of packages will be stored. The ftp download took some time.
What you get in /usr/pkgsrc is a huge directory structure with almost nothing in it except a few manifest files. You dont get any code until you compile a package from source. The pkgsrc directory can be updated by ftp-ing a new tar file or by using CVS.
# cd /usr/pkgsrc
# cvs update -dP
Now , lets try and build a package from source.
You can browse the online package index here
https://cdn.netbsd.org/pub/pkgsrc/packages/NetBSD/x86_64/10.0_2025Q2/All/
We shall try to build 7-zip-24.09.tgz
Go to the 7-zip subdirectory in pkgsrc
and type ‘make’
followed by make install
Well I did not know that would interfere, try again
# unset PKG_PATH
# make
I get pages of configure and compiler output… it hunts down all the dependencies, including make itself. It ends like this
It says it installed the binary in /usr/pkg/bin. I cant find it there?
Do some searching
Looks like it renamed the binary 7zz. I cant be sure, there is no man page for either 7-zip or 7zz?
I can check my looking at the Makefile
Yes, it installs the binary to /usr/pkg/bin/7zz. Confusing?
If I type 7zz I get a 7-zip usage printout. That confirms it.
After finishing one can do
# make clean
# make clean-depends
to tidy up leftovers from the compilation.
There is more to pkgsrc. It can be configured.
The config file is /etc/mk.conf. It is not present in the system as installed. It allows setting the compiler name, compiler flags, linker flags, and package specific build options. A bit like USE flags in Gentoo.
Updating the system
System updates are separate from the package system. The documentation is here
https://www.netbsd.org/docs/guide/en/chap-upgrading.html
There are several methods of doing a binary upgrade
  • The sysinst method. You start with a .iso file and invoke the installer, but choose Upgrade NeBSD instread of install. It basically does all the install steps except partitioning.
  • The sysupgrade method. This does an inline upgrade of a running system. It requires intervention only for changes to config files.
I have NetBSD-10.0. We are going to try an inline upgrade to NetBSD-10.1
The program sysupgrade is in pkgsrc/sysutils/sysupgrade. It needs to be installed, so another source code install.
# cd /usr/pkgsrc/sysutils/sysupgrade
# unset PKG_PATH
# make
.... lots of compiler output
# make install
# which sysupgrade
/usr/pkg/sbin/sysupgrade
Now I reboot, do a backup, then use the sysupgrade command
Lots of output, including some questions about overwriting config files.
There is some problem with postinstall checks
It seems all fixes passed. So reboot and see if it works.
It boots and I can login.
I had better change PKG_PATH in .profile to 10.1
and, test the binary package system… yes it still works.
I had better set a hostname
# hostname -s netbsdvm
The network connection still works.
I think that was a successful upgrade.
Finding packages
The list of packages available as binaries ( for my system) is here
or it can be searched with pkgin
The list of packages available as source ( for my system) is here
or one can search the directory tree in /usr/pkgsrc.
The latter list seems to contain all the packages also available as binaries.
Things like firefox browser, thunderbird mailer and xfce DE are available .
I am happy with CTWM nostalgic WM.
Mail in BSD
Of course, one can install a modern mail agent like Thunderbird.
What I am interested in is the original BSD mail program
It is present, but requires some configuration
  • a hostname has to be set
  • directories need to be added to /var/spool/postfix
    specifically maildrop and public and their ownership and group needs to be as shown
  • the postfix service needs to be running
Given that, I can do
You terminate the typed message with Ctrl D. When you say mail it displays all unread messages. You can step through them with + and -.
You can pipe a message to mail from another program, it is compartable with all text processing utilities.
That is internal mail. You can also configure it to receive network mail.
I worked with mail for years. I believe it is still around in Linux, but have never tried. It was just interesting to go back to it, in the present context.
Virtual Memory
Unix, including SysVUnix and BSD, was one of the first operating systems to implement virtual memory … the system of dividing physical memory into pages and swapping pages between real memory and disk swap space, while all the time making it look to the user as if they had a large continuous slab of memory.
We take it for granted today, but it made multi-user systems feasable and allowed programs requiring large amounts of memory to run.
BSD still has the vmstat utility which shows how much memory is in use and whether there is pageing activity. Some Linuxes still have it.
My NetBSD in VM has 4Gb of emulated physical ram and a swap space. Lets see if we can make it swap
cd /usr/pkgsrc/www/netscape
unset PKG_PATH
make
Compiling Netscape may make it swap
Well it has page faults but no ‘pi’ or ‘po’. So it is accessing pages already in memory, but not swapping them to disk. It has a lot of free memory. I thought compiling would take more than that?
The package is ‘netscape-20040123nb4’ . Netscape discontinued in 2007, so this must be an old package.
It seems to be downloading firefox 138.0.4? Must be some dependency there.
I reduced it to 1Gb of ram.
Lots of page faults, lots of pages freed ( it is discarding pages from finished processes) , 5 reactivated pages, but still no swapping.
Reduce it to 128Mb of ram.
At last, some real pageing activity, the ‘pi’ and ‘po’ columns are active.
It is amazing how little ram NetBSD will run in.
I remember having a 486 with 128Mb of ram , and it ran FreeBSD-1.x quite happily, including TWM and Netscape. I thought a modern BSD might need more ram than that.
I will increase the ram now, and let it finish compiling Netscape.
The Netscape browser
Why Netscape? Well, this is a nostalgia trip. Netscape is the first browser I ever used, and I used it in FreeBSD and SunOS in the 1990’s. Mozilla Firefox is a descendent of Netscape Navigator.
I abandoned the compile and installed the binary
#pkgin install netscape-200401234nb4
It installed 52 packages ( including firefox-138.04)… lots of dependencies.
It was a total letdown… it ran firefox instead. Looks nothing like the original Netscape.
Discussion
This is not a review of what NetBSD can do today… it is an attempt to wind NetBSD back to what I remember BSD was like in the 1990’s.
So dont judge NetBSD by what you see here. It is a capable modern OS.
I might try and have a look at modern NetBSD, but that is another topic.
What did I achieve from my nostalgic windback? Apart for some personal satisfaction at seeing old things, there is something to be gained from the contrast.
It was more difficult to configure things in early BSD.
I also learnt how to drive NetBSD… it was an effective way of doing that. The package system is different to any other Linux/BSD and takes some practice to get things working. The update system seems very efficient. The package and update systems are separate… not like Debian where apt does it all. That is a BSD feature ( FreeBSD is the same). It is because BSD keeps the system away from package installs. BSD treats the utilities as part of the OS, while Linux treats utilities as just another addon package.
I have no intention of using my nostalgic creation. It was the journey, not the end point , that meant something to me.
Thank you! Netscape was my first browser also. I’ve also used NetBSD(or FreeBSD) for a short time about 15 years ago. Nice writing, brings memories! I haven’t even seen the original BSD. My first computer experience was 8086 with MS DOS and at home C=64, my friend had an MSX.
C64, 64K of ram, basic on a rom. Great design for its time.
There is a recreation of the original hardware coming on the market soon if not already there.
I saw that too. I don’t miss C=64 and won’t waste money on it!
@nevj :
thanks for providing a brilliant account of you´ve achieved.
I read it through and it seems very impressive. Well, I have to admit I´ll have to read it a few times more to get the hang of it all. :wink:
You´re very knowledgeable and your report is certainly an inspiration to many of us. :+1:
Thanks again and keep up your valuable work.
Thank you for kind words.
I think you overrate me… everything I do these days is a struggle, while other people seem to breeze through things.
you´re very welcome. :heart:
By no means.
Perhaps I already mentioned it in the past, but I´d certainly like to repeat myself:
The way you go about investigating such topics/projects as this one is very academic. It´s straightforward and precisely to the point.
I like this approach particlarly well:
It clearly shows that you´re willingly taking the audience with you on your adventurous trip. So we can consider ourselves to be part of your journey. It definitively adds to a positive learning experience. :+1:
Thanks again for your effort, Neville.
I suppose one could say it is an experimental approach.
I certainly dont start out as ‘full book‘ on a topic. I learn as I go.
I think most people should approach computing that way …. dive in, make mistakes, and learn from them.
