the weirdest thing happened to me yesterday: my wireless mouse (“Genius NX-7000 Funk-Maus”, lsusb says: Bus 001 Device 004: ID 0458:0185 KYE Systems Corp. (Mouse Systems) )
became super-responsive out of the blue.
Using Lubuntu 18.04.4 LTS, 64bit I should be able to use the menu: settings ------> Keyboard and Mouse
(or command “lxinput”) and control the settings for acceleration and sensitivity. But changing the position of the respective sliders has no effect whatsoever.
I turn off the touchpad on my laptop, on every boot. I think I just used the @reboot item of the cron repertoire. But there are different solutions available:
@Akito:
Hi and thank you so much for your suggestions and the links.
I´ll read them through which might take whiile by the look of it.
But good to know there are ways of achieving my goal.
Some points seem to remain a mystery though.
Why on earth did my mouse all of a sudden become super-sensitive all by itself…
Why don´t the sliders in the settings-GUI have any effect…
Why aren´t the settings using xinput permanent…
Never mind; with your help there seem to be some workarounds.
Hi @Rosika, I run Linux Mint and had a bad problem with a jumping mouse cursor. I was able to disable the touch screen permanently at
Edit /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems.
This may not be the same for Ubuntu but may give you a clue as to where to look.
I also found this on the internet which sounded like it might be a match for you.
and the locate command yields no hits even in other places.
Never mind. Thanks for the link. I have to read it through and am interested if I can find help in it.
As soon as I come up with a solution I´ll post it here.
after looking through the links you provided (quite some literature I must say )
I found the easiest soultion to tbe that one:
I added the command xinput --set-prop 9 273 -0.5
to autostart.
The command lxsession-default-apps gives me the respective GUI. The tab “Autostart” provides a field where I entered the above command and clicked on “Add”.
That´s it.
Afterwards I logged out and in. And indeed my mouse pointer behaves as it used to and isn´t super-sesitive any more.
I also checked with a command:
