I didn’t notice this problem until after I updated to Ulyssa, so I can’t say if it was there before.
The problem is that when I right-click on apps to add a shortcut to the Panel nothing happens if the app is listed in the following categories: All Applications, Accessories, Administration, Preferences, Places, and Recent Files.
If the app can be found any of the remaining location then it works fine. For example, Lutris, Steam, and PlayonLinux work as expected in the Games but not when making the attempt in All Applications.
Thanks in advance for the attention and help.
-Edgrin2
System:
Kernel: 5.4.0-72-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Machine:
Type: Desktop System: Gigabyte product: GA-78LMT-S2 v: N/A
serial:
Mobo: Gigabyte model: GA-78LMT-S2 v: sex serial: BIOS: Award
v: F6 date: 01/09/2014
Battery:
Device-1: hidpp_battery_0 model: Logitech M570 charge: 95%
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: Discharging
CPU:
Topology: Quad Core model: AMD FX-4300 bits: 64 type: MCP arch: Bulldozer
L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 30532
Speed: 1481 MHz min/max: 1400/3800 MHz Core speeds (MHz): 1: 1406 2: 1406
3: 1405 4: 1406
Graphics:
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: VISIONTEK driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1280x720~60Hz, 1680x1050~60Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.4.0-72-generic LLVM 11.0.0)
v: 3.3 Mesa 20.2.6 direct render: Yes
Audio:
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: VISIONTEK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-72-generic
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel port: de00 bus ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
Drives:
Local Storage: total: 931.51 GiB used: 171.36 GiB (18.4%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
Partition:
ID-1: / size: 903.97 GiB used: 171.15 GiB (18.9%) fs: ext4 dev: /dev/sda3
ID-2: /boot size: 937.0 MiB used: 208.4 MiB (22.2%) fs: ext2
dev: /dev/sda1
ID-3: swap-1 size: 11.18 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:
System Temperatures: cpu: 11.1 C mobo: N/A gpu: radeon temp: 49 C
Fan Speeds (RPM): N/A
Info:
Processes: 215 Uptime: 4m Memory: 7.77 GiB used: 2.37 GiB (30.5%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17
inxi: 3.0.38
