I have a client who is using linux mint mate 64 bit version 19.1 she has been on linux for over 5 years so no problems on general i just keep upgrading her as needs be when hard disk died etc.
My problem is for some reason she looses the menu button and bottom task bar on a regular basis so i have to drop round and reset it using terminal and sudo
gsettings reset-recursively org.mate.panel
I have tried other fixes similar
She blames the cat during the night playing with the mouse !
I think it a keystroke of her
I want to write a icon, or menu button command that i can just click to reset but not sure how to create this
Think i need
Sudo gsettings reset-recursively org.mate.panel
But as that needs a password which i know to do but dont know where on command line to put it
Or
I need an option to lock menu and panel that needs a password to allow changes thus preventing her from doing it
She dose not have access to terminal as removed that from her list
Its like locking changes to the desktop …
Thanks
