I like the ‘read aloud’ function in Microsoft Edge. After the latest update and possibly the one before the ‘read aloud’ function seems to be missing. Normally you click on the Immersive Reader icon and then ‘read aloud’ is on the toolbar. The voices are really good too.
I use “festival” and “espeak” to do text-to-speech. For example, on login my system announces my display manager:
echo $DESKTOP_SESSION>~/tmp.txt ; festival --tts ~/tmp.txt
Noticed that too. I missed that feature. To get around this, at least temporarily, I’ve downloaded an older version (98). Although, IDK if Microsoft is going to include it again in future releases.
Yes, it´ll read whatever you throw at it.
Just copy any text and insert it into e.g. a script.
I use it this way (running the script I´ve written):
/home/rosika/Desktop/Kopie_Skripte/tts_script_7_deLuxe_focal.sh
Programm starten? Eingabe: j, n j # start the script
bitte wählen Sie die gewünschte Sprache aus: # choose language/variations
Englisch=1, Deutsch=2. schneller Deutsch=3, sehr schnell Deutsch=4, eng_mod=5 1
This is an example text. # example
Warning: an existing sandbox was detected. mplayer will run without any additional sandboxing features
MPlayer 1.3.0 (Debian), built with gcc-9 (C) 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /tmp/test.wav.
libavformat version 58.29.100 (external)
Audio only file format detected.
Load subtitles in /tmp/
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 16000 Hz, 1 ch, s16le, 256.0 kbit/100.00% (ratio: 32000->32000)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
AO: [pulse] 44100Hz 1ch floatle (4 bytes per sample)
Video: no video
Starting playback...
A: 1.8 (01.7) of 2.0 (02.0) 0.5%
Exiting... (End of file)
Programm starten? Eingabe: j, n n # end script or start it again
Das Programm wird nun beendet. # signoff-message
If you or anyone else might be interested in the script I´d be glad to share it.
It´s a pretty simple script though.
Many greetings from Rosika
BTW:
The message concerning the sandbox results from running the script within firejail.
Of course it´s possible to run the tts-script outside it as well.
