I left a week ago to travel to my mom’s house. When disconnecting my laptop (MX Linux 23.5 ahs) I powered it back up without the external monitor and noticed it showed the splash screen, but then it sat at a blank, non-blinking cursor on a black screen. No soft boot would work to restart. I figured I would fix it once I got there.
It is a dual boot with Garuda OS, and Garuda boots and works fine. So video card is not out. I do have both internal & external GPUs.
No matter what I tried, how many topics searched, including here on ItsFOSS, nothing has fixed this. I have used Timeshift restore from the day this happened and continuing to restore all the way back to May 24 and still the same thing.
I do not know much about TTY, but thought I would see if that was possible from this unknown screen. Ctrl-Alt-F2, and was asked to login. I did. But I had no idea what to do to resolve the issue from there. What commands should I run?
From the working GRUB menu, I have chosen advanced and every kernel available without success. I have used “e” to add nomodeset before booting, this also results in the same black screen. I have tried live session with Boot repair, Grub repair, and nothing fixes this.
Obviously, it is a video issue that I cannot advance to the login screen, correct? But I have no idea why it was working fine the day I left home. I did updates, and remember there were kernel updates, but falling back to an older one should have fixed it if that was the issue.
Other than the updates, I simply powered down the laptop and unplugged it from the hdmi external monitor and only rebooted it without an external monitor attached as I needed to test if I should bring the power cord, since I have a USB C power delivery port, figured I could use the same USB C power adapter from other laptop for this one–reducing an extra power cable in transport. It was then that the issue first occurred.
As I said, I did not have time to deal with it then, but a week at my mom’s trying everything I can think of, has not yielded success.
Does anyone have any tips for resolving this?
Thanks,
