Newbie: Will Cinnamon 20.2 automatically give me the option to upgrade to 20.3?
Will I be able to download/install 20.3 over the Internet?
Thank you!
jbiwer - Eden Prairie, MN USA
The Update Manager usually provides an option to update to the latest version of Linux Mint.
The option is located under the ā€˜Edit’ tab.
In Mint shortly after the new point release becomes final Clem will give instructions on how to upgrade from 20.2 to 20.3. Just keep and eye on the release announcement in the Mint forums. It works quite well and smooth. For new major releases say to 21 or 22 when they come next year I would recommend doing a fresh new install.
Good luck.
I’ve always chosen to back up my data and make a fresh install instead of using any distro’s upgrade process. Sort of like wearing a belt and suspenders, but it’s safe.
I wonder whether upgrading from Mint 20.2 to 20.3 is beneficial. I would wait for the 22 version highly likely forthcoming in May-June this year .
Frank in County Wicklow -Ireland
Frank, I upgraded from 20.2 to 20.3 and find no difference except for the addition of the superb piece of software - Warpinter! It is the one I adore as I have a desktop and a laptop which I like to maintain as a ā€˜pair’, meaning I want to transfer various files from one to the other, often quite a large number. I have used Dukto, but occasionally it doesn’t work, so I end up using USBs, a tedious process. Now I have Warpinter all those problems disappear, I can transfer any and many files over my own wifi network in millisecs!
Warpinter is the reason I upgraded and have no problems by doing so.
I transfer files from 1 PC to another through Anydesk.
Have you tried using the old fashioned ftp or the modern sftp ?
You can also mount the PC’s disk on the laptop with NFS, but only while they are linked.
Most web browsers these days disable ftp…
Ran into this couple years back - I’d scan stuff on my MFC to an FTP ā€œshareā€ on my NAS… I could use a browser to look at them (and even showed thumbnails!)… But Chrome / Chromium killed FTP (and Brave too I think)…
But I discovered I can use FTP through Nautilus on my Pop!_OS systems…
When I need to copy a bunch of files (big or small) I mostly just use rsync in a terminal…
I had to use rsync to do some work recently - copy a large DVD ISO (14 GB) image of a Linux distro (the big one now owned by IBM) - and SCP kept bombing out… and so did rsync with common options :
rsync -av source.ISO user@host:~
I ended up doing this instead :
rsync -P -av -e ssh source.ISO user@host:/var/tmp/.
(to two different machines)
and it worked… The rsync client was the one that MobaXterm gets from the Cygwin build they grab their ā€œcodeā€ from… I’ve no idea why ā€œ-e sshā€ would fix it - ā€œ-Pā€ just shows a progress indicator…
I never use ftp in a browser. Either CLI or with Thunar into a VM.
Yes rsync is easier for a bunch of files
Same here… I won’t pretend I want more desktop Linux for users afraid of the CLI… I don’t even care - if the CLI scares you - by all means, go away - and try that sh!t in CMD or PowerShell…
If you want to be a ā€œpower userā€ of MS Windows - you will have to use CMD or PowerShell…
Same goes for MacOS…
Why should Linux be any different…
If you’re a casual user - by all means - use Ubuntu or MacOS… But if it gets too hard (and all the howto’s point you back at the CLI) - go back to MS Windows…
I kinda prefer Desktop Linux to have the minimal user footprint it has - and I’m not about to start prosetylising it’s virtues - even though I might seem a casual dilettante with Ubuntu and Ubuntu based distros… I’m not a zealot - whichever distro gives me a decent shell (e.g. bash or zsh) the easiest - is the one I’ll use…
That goes along with your idea that distros are throwaway items not pampered pets.
