I designed it and would like some constructive criticism, I hope it helps you in your Linux journey.
https://www.help-choosing-a-linux-os.org/
Hello, looks great but I looked at manjaro. The link to forum takes me to mageia!
Cheers,
Thanks for the update on your project
Just couple of addition on my part
old machine (does not ask 32 bit or 64)
and how much memory I have …
If u have 32 bit and 1 gb I am limited on versions available, perhaps at that stage you suggest install memory or how to check 32 or 64 …
There is always one !
I fixed it. The fix is live
I did a quick fix for 32 bit computers. each OS listing has the amount of disk space it requires.
