I am new to Linux and have just installed Mint on an Asus VivoMini. When I boot up it loads as far as the grub> prompt, but then stops. If I type “exit” it carries on and Linux loads normally. But why does it stop at grub> ? It’s a simple single boot system, nothing complicated. I think it may need some instructions loading at the grub> prompt, but I’m not sure what they should be.
Think if you are new to Linux and or mint … then I would do a total new installation again to see if that clears the fault… if not then follow the ideas given in the reply by 7blade and the link suggested.
Thank you 7blade. That worked perfectly. Unfortunately it didn’t solve the problem, so I’ll have to keeo looking.
callpaul.eu
I’m not confident that doing a re-install would make any difference, but I have handed the install usb stick back to the owner, so that’s not an option.
Thanks 7blade. That certainly looks like the same problem I have, but the detail is way above what a beginner like me can understand … and they still don’t seem to have solved the problem. So I’ll wait a little longer in case anyone can suggest something else, then, if not, I’ll just have to live with it.
Hi Akito.
I have finally got around to doing what you suggested and I’m pleased to report that it worked. I don’t know why it didn’t work the first USB stick, maybe it was an earlier version of Mint. However I’m very pleased to say that I’m now a happy bunny and thank you for your advice.
