I added a second Linux Distro to my system. Ran the sudo update-grub, it found the second system and set up a boot menu for me to choose which system to boot from. All was fine.
When I was finished testing the second Linux system, I deleted the partition.
I then ran apt-update grub again, thinking it would remove this system from the boot menu.
Instead my system now boots to Grub>
After trying to fix the problem by doing Clonezilla restore, I gave up and just re-install Linux from the Distro USB. So, I can not try any suggestions but would like to hear what you think I did wrong -or
what I should have done to remove dual boot.
âapt-update grubâ is not actually a âthingââŚ
I canât remember what the exact grub command is - havenât run grub for a while (last time I did anything in grub was to make/force Orrible [sic] Linux âOELâ running in HyperV NOT use the UEK kernel, which breaks in Microsoftâs shoddy half-arsed virtualization platform-from-hell)⌠in ZSH if I run âgrub[tab tab]â it shows this :
â°â⤠grub-
grub-bios-setup grub-glue-efi grub-menulst2cfg grub-mkimage grub-mkrelpath grub-ntldr-img grub-script-check
grub-editenv grub-install grub-mkconfig grub-mklayout grub-mkrescue grub-probe grub-set-default
grub-file grub-kbdcomp grub-mkdevicemap grub-mknetdir grub-mkstandalone grub-reboot grub-syslinux2cfg
grub-fstest grub-macbless grub-mkfont grub-mkpasswd-pbkdf2 grub-mount grub-render-label
So - I think what youâre looking for is one of these doohickeys⌠it was âgrub-set-defaultâ that I had to use in Orrible Enterprise Linux in HyperVâŚ
I donât really know that much about grub, I never, hardly ever, dual boot, so I just let Ubuntu installer do all the automagickery for meâŚ
Thanks @daniel.m.tripp, I should have type âsudo update-grubâ. I will edit my post.
On my old pc I use for Linux testing I have Mint Cinnamon on a ssd and three Distros booting from an hdd. The ssd is set first to boot in the bios with grub installed to the mbr of /dev/sda. I install grub to the other Distros to the root partition of each Distros /devsdb1, /dev/sdb2 and /dev/sdb3. Their is really no need to install grub to these Distros, but the installers does not always give an options to not install grub. The key here is after installing a Distros to /dev/sdb is to reboot and boot into the ssd and run the command sudo update-grub and I let Mint find the other Linux OS. Mint is the only OS that I run the sudo update-grub.
Remember, Grub2 and Linux boots in stages and the first stage is my Grub2 entry in /dev/sda, from their it will try and find the linux image, or a Windows OS, of the OS I have selected. I can delete every partition, except Mint and still have a PC that will boot.
I also use Grub Customizer with Linux and EasyBCD with Windows.
