I installed OBS Flatpak Yesterday on my Ubuntu 24.04 LTS, I tried to record my Screen but it could not happen - the sources list didn’t have the Display Screen Recording or Screen Source (I forgot correct Source name).
So, I did a update, upgrade, flatpak update for any package missing for OBS - the apt update didn’t go through, so I did a restart of Ubuntu
After Restart - Black Screen Right Side Top showing “checking media_” my HDD didn’t shown up - went to BIOS Settings it didn’t shown up - EFI and EFI PXE NETWORK were present - EFI is in Grey not able select as BOOT - tried with Secure Boot Enabled, didn’t go through
Before installing OBS did a Stress test on my HDD to get Read & Write Speeds using fio package - it worked fine after the test
Bought BX 500 SDD installed Fedora 40
I need to Recover my Data from HDD
So, when I tried to mount my Ubuntu HDD - I am not able to do it
created a HDD folder in /mnt dir
sudo mount /dev/sdb /mnt/hdd/
mount: /mnt/hdd: wrong fs type, bad option, bad superblock on /dev/sdb, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
sudo fsck /dev/sdb
fsck from util-linux 2.40.1
e2fsck 1.47.0 (5-Feb-2023)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/sdb
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
How can I go ahead
kovacslt
(László Kovács)
27 September 2024 15:18
2
First, we don’t mount a whole drive, but a partition on it.
What does
lsblk
output?
kovacslt
(László Kovács)
27 September 2024 17:26
3
Second, I’m afraid this disk just died.
I’d like to see the output of smartctl as follows:
sudo smartctl -a /dev/sdb
Assuming sdb is the disk in question.
You may need to install smartmontools package to have smartctl:
sudo apt install smartmontools
Hi
Please check output using smartctl
Let me know how can I get my data back
sudo smartctl -a /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.10.11-200.fc40.x86_64] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Mobile HDD
Device Model: ST1000LM035-172
Serial Number: WES0
LU WWN Device Id: 5 000c50 09c
Firmware Version: LCM2
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Sep 29 19:23:05 2024 IST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 167) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 075 055 034 Pre-fail Always - 159118227
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 037 037 020 Old_age Always - 65535
5 Reallocated_Sector_Ct 0x0033 090 090 036 Pre-fail Always - 6233
7 Seek_Error_Rate 0x000f 081 060 045 Pre-fail Always - 138080067
9 Power_On_Hours 0x0032 078 078 000 Old_age Always - 19543 (160 179 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 090 090 020 Old_age Always - 11068
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 3097
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 25770197005
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 067 044 040 Old_age Always - 33 (Min/Max 32/33)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 262
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 458
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 251115
194 Temperature_Celsius 0x0022 033 056 000 Old_age Always - 33 (0 19 0 0 0)
196 Reallocated_Event_Count 0x0032 090 090 000 Old_age Always - 6233
197 Current_Pending_Sector 0x0012 099 096 000 Old_age Always - 96
198 Offline_Uncorrectable 0x0010 099 096 000 Old_age Offline - 96
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 4
240 Head_Flying_Hours 0x000f 079 079 030 Pre-fail Always - 18986 (123 163 0)
254 Free_Fall_Sensor 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 2757 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2757 occurred at disk power-on lifetime: 18307 hours (762 days + 19 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 00 00 ff ff ff 4f 00 00:18:51.111 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 00:18:51.007 WRITE FPDMA QUEUED
60 00 08 ff ff ff 4f 00 00:18:50.504 READ FPDMA QUEUED
61 00 c0 ff ff ff 4f 00 00:18:47.275 WRITE FPDMA QUEUED
61 00 00 ff ff ff 4f 00 00:18:47.274 WRITE FPDMA QUEUED
Error 2756 occurred at disk power-on lifetime: 18307 hours (762 days + 19 hours)
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
60 00 08 ff ff ff 4f 00 00:18:41.132 READ FPDMA QUEUED
61 00 00 ff ff ff 4f 00 00:18:41.104 WRITE FPDMA QUEUED
61 00 08 08 7c 0b 45 00 00:18:41.104 WRITE FPDMA QUEUED
60 00 08 ff ff ff 4f 00 00:18:41.078 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 00:18:41.042 READ FPDMA QUEUED
Error 2755 occurred at disk power-on lifetime: 18307 hours (762 days + 19 hours)
60 00 00 ff ff ff 4f 00 00:18:04.947 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 00:18:04.804 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 00:18:04.802 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 00:18:04.779 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 00:18:04.757 READ FPDMA QUEUED
Error 2754 occurred at disk power-on lifetime: 5619 hours (234 days + 3 hours)
40 51 00 cf a5 e3 09 Error: UNC at LBA = 0x09e3a5cf = 165914063
60 00 01 cf a5 e3 49 00 02:04:34.004 READ FPDMA QUEUED
2f 00 01 10 00 00 20 00 02:04:33.992 READ LOG EXT
60 00 01 ce a5 e3 49 00 02:04:33.863 READ FPDMA QUEUED
2f 00 01 10 00 00 20 00 02:04:33.861 READ LOG EXT
61 00 08 00 da 12 40 00 02:04:33.816 WRITE FPDMA QUEUED
Error 2753 occurred at disk power-on lifetime: 5619 hours (234 days + 3 hours)
40 51 00 ce a5 e3 09 Error: UNC at LBA = 0x09e3a5ce = 165914062
60 00 01 cd a5 e3 49 00 02:04:33.754 READ FPDMA QUEUED
2f 00 01 10 00 00 20 00 02:04:33.739 READ LOG EXT
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Conveyance offline Completed without error 00% 7311 -
# 2 Vendor (0x50) Completed without error 00% 7310 -
# 3 Short offline Completed without error 00% 7310 -
# 4 Vendor (0x50) Completed without error 00% 6644 -
# 5 Short offline Completed without error 00% 6644 -
# 6 Vendor (0x50) Completed without error 00% 3087 -
# 7 Short offline Completed without error 00% 3087 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
kovacslt
(László Kovács)
30 September 2024 09:46
5
Those indicate the disk is defect. Backup what still can, and forget that disk.
Any package/software help me get my data back from HDD
Found Testdisk, Photorec or Qphotorec using them can I get back
kovacslt
(László Kovács)
30 September 2024 13:22
7
The first thing I’d try is to create an image of the defect disk with ddrescue. This is the hardest part.
https://linux.die.net/man/1/ddrescue
I don’t use Fedora, so have no idea which package it is in.
After that I’d loop mount the defect disc image, and run photorec on that image.
After executing losetup -Prf the rest of the system will see the image as /dev/loop##, lsblk wil report it too.
Then you can run photorec against that “drive”.
Edit:
This is a 1TB disk, expect the resulting image to be that size.
Another big space is required where photorec will sotre what it finds.
TypeHrishi
(Hrishikesh Kelkar)
1 October 2024 03:16
8
Ill prefer testdisk…its really good…photorec is also awesome…i even recovered encrypted files by ransomeware using it.
But see this, testdisk tries to make the partition usable and fix the partition while photorec tries to recover files…
Once my Sanskrit teacher gave a sd card to me which was not showing the files on it in her phone…
So i brought it home, used the sd card to usb coverter and plugged it into my linux machine. Then I simple used testdisk to recover the partitions. Let me tell u that it didnt even take a bit of storage on my 256gb ssd(except the space taken by testdisk tool) and it directly repaired the filesystem on the sd card and it was now readable, writable!
So ill recommend to try that.
Corrections if any pls tell @Senior Members
kovacslt
(László Kovács)
1 October 2024 04:26
9
Indeed Testisk is worth to try too.
But do it on a copy of the rescued disk image. So in case it fails, doesn’t make things worse. For that loop mount the image read/write mode.
TypeHrishi
(Hrishikesh Kelkar)
1 October 2024 04:56
10
Yeahh that would be safer actually…
