hai, please recommend a Linux based independent operating system which have mozilla firefox browser with version 60, suitable for a thin client work station.
I can’t recommend a specific one, but you can look up distributions focusing on acting as a Thin Client:
https://distrowatch.com/search.php?ostype=All&category=Thin+Client&origin=All&basedon=All¬basedon=None&desktop=All&architecture=All&package=All&rolling=All&isosize=All&netinstall=All&language=All&defaultinit=All&status=Active#simple
Hareesh, how large a thinclient setup are you doing?
Wade,
I am using hp Compaq vc4725 LNX thin clients. It’s have VIA C7(1.0 ghz) processor , 2gb RAM and 2gb flash memory attached to it.
regards,
Hareesh
Doesn’t it have an HDD?
Is this Thin Client suppose to boot from the server?
Or is the 2GB flash it’s boot disk?
it doesn’t have HDD. The 2gb flash is its boot device. A lighter version of OS is required.
Have you tried Lubuntu? I think it can fit into 2GB.
Oh! And, whatever distro you try, don’t forget to download the 32 bit version, since the CPU is x86 architecture, not x64.
thanks to all for your help
